HELP!!?? rear brake help needed
Old Mar 15, 2008 | 05:40 PM
Garage 808 Hatch's Avatar
Default HELP!!?? rear brake help needed
OK, here's the setup.
89 CRX SI
Stock master
stock booster
DA front brakes
CNC staging brake
Inline proportioning valve
MB straight axle with wilwood single piston calipers
got the system all bled today, even with the proportioning valve all the turned down, the rear brakes lock up at like 5mph. = disasterous at high speed. anyone experience this before, and what did you do to resolve this?
Old Mar 15, 2008 | 05:53 PM
DaveF's Avatar
Default Re: HELP!!?? rear brake help needed (Garage 808 Hatch)
<FONT SIZE="4">sell me your straight axle.</FONT> i need it ! [/B]
disconnect you back brakes from the front. you dont want them like that. like you said "disasterous at high speed" ask Danny Tran..
Old Mar 15, 2008 | 06:11 PM
Default Re: HELP!!?? rear brake help needed (DaveF)
what do you mean by disconnect it from the front? have a seperate reservoir for the staging brake, and just run the fronts off the pedal?
Old Mar 15, 2008 | 09:31 PM
jjspec's Avatar
Yes
Old Mar 16, 2008 | 12:16 AM
Default Re: HELP!!?? rear brake help needed (jjspec)
is this a common practice? does anyone have this setup with it still being used off the brake pedal? and if so, what parts to make it work?
Old Mar 16, 2008 | 04:57 AM
DaveF's Avatar
have you looked into a wilwood adjustable proportioning valve ?
most all of your Pfwd/hotrod cars are setup on seperate brake systems. i know we only use the rear brake to burnout/stage. other than that. we never use it... oh yea. and as an "ebrake"
Old Mar 16, 2008 | 08:55 AM
i have an adjustable valve that is next to me in the car, i had it fully adjusted both directions, and both times, it was instant lock. looks like i'm going to try and find a reservoir for it, and plug the rear line from the master
Old Mar 16, 2008 | 04:42 PM
Anyone else have any input for me? i'd like a couple more suggestions/confirmations soon, so i can finalize my setup and get to the track next month
J_24
Mar 2, 2015 12:30 PM
rexfan
36
Aug 31, 2009 11:43 AM
darwin22
Aug 18, 2004 12:55 PM
Davanca
11
Mar 15, 2004 12:27 PM
LL
Jul 23, 2001 04:07 PM
