HELP! clutch problems
Old Jul 9, 2009 | 11:50 AM
88ED8's Avatar
Default HELP! clutch problems
Long story short, clutch starts slipping on the dyno (just shy of 400whp), I drop the trans and this is what I find. Mind you this is a new clutch disk with a tested good pp from CC (Competiotion Clutch stg5 clutch kit) and a new Fidanza flywheel all of wich have been in the car for about 500miles
I have no idea why the pucks are wearing unevenly but they are...
Pucks on flywheeel side: mostly wearing on the outside of the pucks.
Pucks on pressure plate side: mostlt wearing on the inside of the pucks.
What could cause this?
Old Jul 9, 2009 | 12:28 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: HELP! clutch problems
It looks like the disc isn't fully seated. How many miles does it have on it? If you just installed it and ran it without giving it a chance to seat fully, it could cause it to slip. It could have a bent disc. If the trans was forced on, like pulling it on with the bolts or something, it could cause this too.
Old Jul 9, 2009 | 12:31 PM
25 Year Member
It also looks like you have some sort of grease coming from the input shaft that could be effecting it as well.
Old Jul 9, 2009 | 12:49 PM
88ED8's Avatar
It is a H2B set up, I sit the trans on the dowels then thread the bolts and torque everything down (never force).
The grease you see is a lot less in person (flash lights it up making it look like a lot).
Those pics were taken this morning, clutch has around 500 miles on it.
How many miles should be on a clutch for it to fully seat?
Maybe the pp is weak?
Old Jul 9, 2009 | 12:54 PM
25 Year Member
If the disc is not bent, it looks to me like it is not broken in yet
Chaser4dr
Aug 16, 2007 06:05 PM
TOP END MS
Dec 15, 2006 07:06 PM
CLE
Sep 19, 2006 04:30 PM
1999all_motoR_teg
Oct 15, 2004 12:00 PM
