heating radials
Old Mar 27, 2006 | 08:35 PM
watsvtecEK's Avatar
Default heating radials
I herd that if you heat up radials they will get oily and grip less then when dry. is this true? sorry for the noob question.
Old Mar 27, 2006 | 09:09 PM
dunkd's Avatar
im gonna go out on a limb here and say no.
Old Mar 28, 2006 | 12:06 AM
ImportMotorSpec's Avatar
Default Re: (dunkd)
I'm gonna go with dunkd and say probably not.
Unless you are getting the tires to teh point where the rubber is melting off teh tire, but then you will have more issues...lol
Old Mar 28, 2006 | 12:23 AM
95GLX's Avatar
Default Re: (ImportMotorSpec)
all depends on the tire. Check with the manufacturer, BFgoodrichs really like the heat. My experience seems to show that a quick scrub, 3 second burnout is all you need. Get any rocks, debris off them and get them warmed up just a little.
Do it on the dry pavement in line with the track of a real sick car that just did a burnout before you. Scrub the tires a few seconds and then roll straight through to stage. Try to stay on that slick cars lines.
Radials can get greasy if you burn them out to much but takes a lot!
anthony
Old Mar 28, 2006 | 05:30 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (95GLX)
bfg's have always done better the hotter i get them.i don't think a fwd will stay in the burnout box long enough to get them as hot as i wanted them
Old Mar 29, 2006 | 01:18 PM
Rico's Avatar
Drag radials no matter what brand or size needs to be heated up to grip better. Each tire has to reach a certain surface tempature for maximum performance.
s2000tracknut
May 22, 2017 02:29 AM
90_EX_Civic
Feb 19, 2009 11:41 AM
thawley
16
Mar 27, 2006 02:04 PM
5-SpeedFreak
35
Sep 28, 2002 07:24 PM
Markus
19
May 1, 2002 06:45 AM
