Headwork/Flowbench #'s
Old Apr 12, 2011 | 09:15 AM
boostinhard4ya's Avatar
Default Headwork/Flowbench #'s
hi all,
im a full time student and work so this is taking a while, this is my 2nd turbo build, ive been collecting parts for the current build for about 2 years now lol.
Anyway, When I get close to finishing the build in the rents garage il post up a thread with my build process as i hope to be a familiar car down at local tracks. Im going for about 600whp *for now . Chris @ xenocron is my tuner.
So I Just wanted to hear some of your thoughts on my head i just recieved back from Steve @ CCCylinderheads... I dont not know all too much about headflow and that sort so here is the flow sheet..
Spare build info...
84mm benson gsr block
Gsr head
Supertech valvetrain
Hta3082 which is my gt3076r tial .82 housing with a gt35r SIZED comp housing and billet wheel
*undecided on camshafts yet hope input can help
Thanks and i appreciate any input you can give me.
Old Apr 12, 2011 | 01:51 PM
StolenTeg's Avatar
Default Re: Headwork/Flowbench #'s
So it flowed 6.3 more cfm after the port job? that doesnt seem to be much
Old Apr 12, 2011 | 02:11 PM
my guess is he flowbenched it as he progressed through the p&p service, but what do i know... and thats 6.3cfm @.600 of lift.
hello1320's Avatar
Your looking in the wrong place
Old Apr 12, 2011 | 02:19 PM
luck4rmkc's Avatar
Geez is this car ever gonna be done
Old Apr 12, 2011 | 02:36 PM
2k.civic.si's Avatar
what did you pay him to do to that head?
Old Apr 12, 2011 | 02:49 PM
turbohatch96y7's Avatar
Im not sure but it looks like it gained alot of midrange helping the turbo to spool up faster
Old Apr 12, 2011 | 04:17 PM
xenocron's Avatar
I think alot of it depends on what cams you are going to run...obviously, if you dont have 500 lift cams or higher, those numbers dont mean jack since you wouldnt be lifting the valve that high right
Im my opinion...flow bench numbers are just another number, its really all about port velocity and how it works or doesnt with your particular combination of parts.
Old Apr 12, 2011 | 04:38 PM
With that said, I already have the midrange with the 30r turbine housing, this is the direction i was looking to go chris, but what dictates port velocity?
Could i potentially benefit using say the Pro 1s instead of the tuner 1s? With the high lift of the Pro 1s would I be hitting the "sweetspots spots" better?
Old Apr 12, 2011 | 04:44 PM
xenocron's Avatar
With a smaller turbo, you are going to be happier with the Tuner 1s if you want to drive this as a street car...if you are looking for Peak HP and higher rpms...the PRO1s will do that granted you are throwing tons of boost at them and you dont have a restrictive exhaust manifold.
Old Apr 12, 2011 | 04:50 PM
I care about what it will make on e85.
Old Apr 12, 2011 | 05:14 PM
MAX_CFM's Avatar
Looks good for turbo GSR head ...
GSR heads always flow 7 to 10 less than a worked B16
Old Apr 12, 2011 | 05:42 PM
TURBOINTEGRA750's Avatar
Old Apr 13, 2011 | 01:20 PM
MAX_CFM's Avatar
Originally Posted by TURBOINTEGRA750
Your head flowed about the same .. as this guys .. I think you picked up stupid power
Old Apr 13, 2011 | 02:07 PM
Old Apr 13, 2011 | 05:01 PM
xenocron's Avatar
It will do fine
E85 is the best invention since the wheel...
Old Apr 13, 2011 | 08:26 PM
It will do fine
I hope to discover this soon...
cristegra09
Nov 9, 2009 01:11 AM
dj mikey p
Dec 21, 2004 08:01 PM
92eh3si
Jul 4, 2004 08:53 AM
geminis2k
Nov 26, 2002 05:53 PM
