h2b hype, is it worth it?
Old Jan 9, 2006 | 06:43 AM
Missing Gears's Avatar
Default h2b hype, is it worth it?
not trying to start a debate here! im interested in hearing from guys that have had consistant running h series motors/trans. and then have done h2b or have played w/ gear ratios. when i say consistant i dont mean 1 or 2 passes down the track or guessing what a car would run w/ shorter or longer gear ratio.....i mean running a good part of the season on an h22 or h23 stock trans. and then switching to h2b, or changing ratios and then running consistant on that setup for a while. if anyone has done this i would also like to know the power output of the motor at the time.
Old Jan 9, 2006 | 06:59 AM
JDogg's Avatar
Default Re: h2b hype, is it worth it? (Missing Gears)
regardless of hte gear ratios, the MAIN benifit is not having to find h22 trannys when they break... b-series tranny hold u way better to abuse than hseries trannys do
Old Jan 9, 2006 | 07:15 AM
Default Re: h2b hype, is it worth it? (JDogg)
[QUOTE=JDogg]regardless of hte gear ratios, the MAIN benifit is not having to find h22 trannys when they break... b-series tranny hold u way better to abuse than hseries trannys do[/QUOTE
b series trans. break before h series do, especially when putting h series tq to them. anyways not trying to debate, asking people who have tryed this before.....curios to see other peoples results after trying different gear ratios. i have tried several and shorter ratios = slower e.ts.
Old Jan 9, 2006 | 08:09 AM
Antilag's Avatar
I beat the **** out of my h23 tranny for 3 seasons. Pulled to inspect. All the syncros look great 2nd gear looks a little worn not an issue though. Other wise everything else looks great.
Old Jan 9, 2006 | 08:11 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=JDogg]regardless of hte gear ratios, the MAIN benifit is not having to find h22 trannys when they break... b-series tranny hold u way better to abuse than hseries trannys do[/QUOTE
b series trans. break before h series do, especially when putting h series tq to them. anyways not trying to debate, asking people who have tryed this before.....curios to see other peoples results after trying different gear ratios. i have tried several and shorter ratios = slower e.ts.</TD></TR></TABLE>
I just dropped 4 tenths and gained 5mph with the kit yesterday. I went from a M2F4 to a GSR transmission.
Anything but hype.
Feel free to read up: https://honda-tech.com/zerothread?id=1475661
Old Jan 9, 2006 | 08:39 AM
Default Re: h2b hype, is it worth it? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Anything but hype.
Feel free to read up: https://honda-tech.com/zerothread?id=1475661</TD></TR></TABLE>
read up on it! you said last time you ran consistant was in august, i could drop 4 tenths easy in this weather compared to aug. did you really gain anything?
need to try a comparison in the same conditions to get accurate results.
i have done this last season and found the more tq you make, the longer ratio you want. honda wasnt sleeping when they gave h series a longer ratio, they did it for a reason!
Old Jan 9, 2006 | 08:44 AM
would like to here from some pros that have played w/ h series gearing (norris, brauning, etc.)
Old Jan 9, 2006 | 09:11 AM
skunked's Avatar
i have done this last season and found the more tq you make, the longer ratio you want. honda wasnt sleeping when they gave h series a longer ratio, they did it for a reason! </TD></TR></TABLE>
If that's the case why do the SPFWD guys prefer B16/ITR gear box's? Don't try and tell me you make more torque than them Why don't they all run LS tranny's?
4 tenths and 5mph on a 220whp street car is allot, weather alone will not and did not casue these better ET's. My 60's in augsust were mid to low 1.6's and mid to high 1.7's this last weekend. That would put me down in the teens if you take that into consideration.
Old Jan 9, 2006 | 09:24 AM
4 tenths and 5mph on a 220whp street car is allot, weather alone will not and did not casue these better ET's. My 60's in augsust were mid to low 1.6's and mid to high 1.7's this last weekend. That would put me down in the teens if you take that into consideration.</TD></TR></TABLE>
spfwd guys are turbo...completely different! dont compare apples to oranges.
4 tenths is alot, im making close to 270whp, and 190wtq, and i could easily run 4 tenths better now than in aug. to get accurate results you have to run in the same conditions.....its a fact. want to prove h2b works, get a consistant e.t. now and swap trans and run consistant e.t. w/ h trans now in same weather and other conditions......then give me the results.
and again, not trying to debate.......only need to hear from guys that have been running h series trans for a long time consistantly and have played w/ gearing........such as the pros out there familiar w/ h series. thanks
Old Jan 9, 2006 | 09:27 AM
skunked's Avatar
Apples to oranges?
So which statement is true?
Old Jan 9, 2006 | 09:39 AM
1700anddroping's Avatar
ok i am not as nice as the other guys.you just want some one to do
your dam HOME WORK FOR YOU.hell if your scared say your scared
there is nothing wrong w/that.we give you info and you don't like the results.
this h2b kit is the best thing that has come along since PUSS.hell it
IS LIKE PEPSI"BOTH OF THEM" I GOTTA HAVE IT.
here is my set up and i will for ONE will be putting this set up to
the ultimate test.......YES I HAVE BIG *****.
https://honda-tech.com/zerothread?id=1282519
Old Jan 9, 2006 | 10:17 AM
Apples to oranges?
So which statement is true? </TD></TR></TABLE>
last time i checked turbo guys did use ls trannys for longer gearing, but im no expert on turbo stuff.....turbo vs. n/a =apples to oranges.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">ok i am not as nice as the other guys.you just want some one to do
first off i dont need anyone to to my homework.....obviously i have done plenty more than both of you put together. second, nobodys scared around here, we can take it to the track anytime your ready.and third, i asked for a pros imput which you are obviously not. take your useless posts somewhere else.
Old Jan 9, 2006 | 10:24 AM
skunked's Avatar
.</TD></TR></TABLE>
There was just a thread about this right here in the HT forum. The quickest guys run the SHORT geared tranny's. They are easily doubling the torque you have as well. You obviously need to do some homework. 270whp and only a 11.6 to show for it?
I'm not a turbo guy either, but I am a drag racer
well when this car is done WE CAN TAKE IT TO DA STREETS YO..
man miss me w/that bull ****.because we are not pro's you like
to call it...we don't know what we are talking about.i guess the guy that
built this kit doesn't know either huh.
like i said if your SCARED say your SCARED.......
Old Jan 9, 2006 | 10:40 AM
H25's Avatar
H25
H series trannys work great! a tranny is a tranny.. I ran the t2w4 euro R tranny stock with no problems for 4 events straight. then the synchros needed to be replaced. tire size is important too. I shifted my H tranny as high as 9,990 rpms without any problems.
Old Jan 9, 2006 | 10:46 AM
Default Re: h2b hype, is it worth it? (MHRacing-310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">H series trannys work great! a tranny is a tranny.. I ran the t2w4 euro R tranny stock with no problems for 4 events straight. then the synchros needed to be replaced. tire size is important too. I shifted my H tranny as high as 9,990 rpms without any problems. </TD></TR></TABLE>
max if your not a pro...your input doesn't count.i say line'em up
at the track and let that do the talking..then maybe that will shut his *** up.
Old Jan 9, 2006 | 10:48 AM
skunked's Avatar
The H tranny's work when built right..... no doubt. How much are those tranny's Max and how easy are they to get?
missing gears:
https://honda-tech.com/zerothread?id=1428605&page=1
Old Jan 9, 2006 | 10:51 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">i have done this last season and found the more tq you make, the longer ratio you want. honda wasnt sleeping when they gave h series a longer ratio, they did it for a reason! </TD></TR></TABLE>
You are correct, but Honda engineered it as a street car, not a quarter mile car. All torque is the twisting force, more you have of it, more "force" it can move (read: higher gearing, more weight) then you can with less torque. Honda engineered the car for emissions and fuel enomony, then performance.
I do not see why you want a taller gear if you can put the power down and not run out of gear.
What I said in the other thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but when you shift, you are in a lower gear then H-series transmission. Look at the 1st to 2nd shift. You are going to shift into a little lower gear, but accel faster. Everytime you shift, the distance gets larger. You are spinning the motor more, but you are spinning the tires faster at the same time.
If you look at the chart, ITR trans at 7500rpms tops out at about 115 and the M2f4 tops out at about 125.
So with a car that traps less then 115, you are shifting the same (amount of shifts) as the M2f4.
There is always pros and cons. I think for a all-motor set-up, the H2b is the way to go. </TD></TR></TABLE>
Is this the best option for everyone? No, run the mods that suit your needs
Modified by Turbogixxer at 3:12 PM 1/9/2006
Old Jan 9, 2006 | 10:53 AM
JDogg's Avatar
i dunno.. i tore my h22 trannys to pieces in my prelude. busted syncros, broken gears, etc... and that was w/220hp, never ran it at the track. with a 175hp GSR motor my ITR tranny has lasted me over12k miles of HELL w/o a problem. it has about 25 runs at the track, i never lift to shift ( i shift at WOT, 8700 rpms) the h22 was only reving to 8400 and never shifted at WOT (it woudlnt..)
not only that, but WHEN (not if) the h22 tranny breaks, parts and trannys cost more and are harder to find. i bought my ITR tranny for 750bux, i have paid 800 for good low miles USDM 4th gen tranny.. simply because i didnt have any other options. i could get junk h23 trannys for 2-300, but they have longer gears. and everyone knows shorter gears make you faster. i know for a fact that the fastest street class NA car was running a very very short final drive.
Old Jan 9, 2006 | 10:55 AM
boostedh22a's Avatar
I ran for 2.5 years in the PRO4 class. End of 01-03. And through the years I realized that for me at least the limiting factor was gear selection and tranny. I think this is the best idea yet for H-series guys. If you are talking AllMotor, I dont know. But with my 700hp pro car,I would say that was the limiting factor from going ALOT faster and quicker. The gearing on a stock H22/23 box just didn't allow you to go throught the traps at peak power.
Old Jan 9, 2006 | 11:19 AM
RotiEatter's Avatar
Ditto
I am a stupid ******* moron.
I agree.
Old Jan 9, 2006 | 11:48 AM
I'm not a turbo guy either, but I am a drag racer </TD></TR></TABLE>
11.60 was consistant e.ts in hot weather, w/ the motor falling out of vtec every pass among other problems. never got to run in good conditions, dont worry it still had alot left in it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">well when this car is done WE CAN TAKE IT TO DA STREETS YO..
like i said if your SCARED say your SCARED.......</TD></TR></TABLE>
sorry, cant understand your ghetto slang
shorter gearing does not always mean quicker e.ts. obviously every car, motor, driver is different. i have tried several combinations and for my setup h23 gearing works the best.
like i said previously, wasnt trying to turn this into a debate or arguement, was looking for results from people who have played w/ h series gearing .
Old Jan 9, 2006 | 11:51 AM
Default Re: h2b hype, is it worth it? (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">
I agree. </TD></TR></TABLE>
yet another useless post
Old Jan 9, 2006 | 11:58 AM
like i said previously, wasnt trying to turn this into a debate or arguement, was looking for results from people who have played w/ h series gearing .</TD></TR></TABLE>
you obviously don't have a sense of humor.when you said we can take
it to the track.that is what most of the people say from up your way.
you are making 270 hp and how much tq.i think in one of your threads
you say 200.i'm not hating here.but 11.7 w/270 hp 200 tq is not impressive
at all,also how much does your car weigh.
being both motors are stock except for the trannie's.i will bet any amount
you want.that the h w/the gsr tranny will walk the one w/the h22 tranny
and the h23 tranny.
shorter gears let you build your speed quicker,now on the i/s ls 5th
would do you nicely on an h set up.
Old Jan 9, 2006 | 12:00 PM
skunked's Avatar
.</TD></TR></TABLE>
