Gsr vs ???
Old Dec 2, 2015 | 12:19 PM
Eghatchgsr92's Avatar
Default Gsr vs ???
How's it going everybody.
I just recently swapped a gsr into my 92 civic hatch. Not completely sure of the mods other then it was previously boosted. Has full exhaust , headers , pro series(skunk 2) manifold, short ram intake ,motor is partially tucked. Car has all interior ministry thinking of gutting it. But my main questions are for people who have Gsr's or dealt with them on how fast they are. What are some cars I can definitely beat and what cars I'm close to beating. Thank you!!!! B18c1 which comes with 170/180hp stock!!
Old Dec 3, 2015 | 09:36 AM
hondaracing84's Avatar
Default Re: Gsr vs ???
That is really hard to say. So many things to consider. I have a 92 Hatch CX with a GSR motor. Header, cold air, 70mm tb on an edelbrock manifold. Car used to be a sfwd car, so full roll cage and about gutted everywhere else. Its probably a 100lbs or so under sfwd weight. Its fairly quick. But I cannot say your car would be the same because everything is set up different. And that's my point, every setup is different. So asking what cars you can beat or get close to beating is a very difficult thing to say. Also driver is the biggest part in determining that. I might say you can easily beat a civic si with bolt ons based off what my car can do, but you may differ because you don't drive the same as me. So that is a loaded question.
Old Dec 3, 2015 | 10:03 AM
93egSLEEPER's Avatar
Meh. Bench racing.
Go to a track and find out.
Old Dec 3, 2015 | 12:08 PM
Originally Posted by 93egSLEEPER
Meh. Bench racing.
Agreed. Need to go to the track and start racing people.
You can start small and run slow cars and work your way up until you loose. lol
Old Dec 9, 2015 | 09:34 AM
StreetLethaleg6's Avatar
Go Race and FiND OUT!!!! Lol jk.....I had a JDM B18c in my eg hatch for years, boosted and on motor. When my car was just bolt ons: skunk2 gen 1 intake manifold, skunk2 70mm tb, exedy stage 1 clutch + flywheel, 3" intake, CTR N1 Crank pulley, 4-1 headers, 2.5" exhaust(no cat, no res)......The car would run consistent LOW 14s et on regular street tires (205 50 15), my best time with my gsr on bolt ons was 13.9 @ 99mph, that was also on street tires. I am a driver, low 14s aren't so common on a stock setup and a 13 et pass is almost unheard of on regular street tires. Also my car is completely gutted but uncut it weighs 2200lbs with me( I weigh 190lbs). Depending on weather, driver skill, and how healthy the motor is, mid to high 14s are what you can expect. With that said you wont be able to beat many cars now a days with a mid 14 sec car lol. Times have changed, most cars come out the factory running 14s and better and the more expensive cars are commonly in the 13s and 12s.
Old Dec 11, 2015 | 11:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Kill Stories - Honda-Tech
Eghatchgsr92
Dec 27, 2015 04:43 AM
94IntegraRS
Mar 9, 2012 01:32 PM
631 Teggy
Nov 13, 2003 09:29 AM
LSBeast
11
Feb 19, 2002 05:36 PM
