Gforce shifter question
ive been looking at getting one of these shifters for a while now just dont know if i can justify spending all the money on one.
now of all you racers out there are these worth it?
i have just moved from a SOHC build so i dont have shift linkage yet so thats why ive been tossing this around.
the setup will be a sleeved gsr
goal is 800+whp
tranny will be
stock gsr gearing with spool and liberty cuff.
any honest info would be great.
thanks guys
goal is 800+whp
tranny will be
thanks guys
Originally Posted by T1racedevelopment.com
The purpose of this shifter is to help prevent missed shifts. It has a spring inside that pushes the shift lever towards the 5/R gate. In order to get into the 5/R gate, you have to push down and over on the shifter. This helps prevent shifting from 2nd to 5th, but allows you to push all the way to the right on the 2-3 shift to minimize the chance of shifting back into 1st from 2nd. The 1-2-1 shift generally does a lot of damage!
One of the best parts I have installed on my car. It was well worth the money. It pretty much guides it self, you just slam it back, up, back. I just keep a little left tension on it when I hit second.
The T1 kit is good, but the shifter itself doesn't have quite enough movement back and forth. I machined mine to give it more travel and it works flawless now.
The shifter has just enough movement as it comes from G Force, but there's no room for error in linkage length or engine movement.
We realized this early on and all shifters we have sold in the past 2 years or so have been modified by us for increased travel before shipment.
If you are running a stock trans dont waste your money. It is damn near imposible to 1-2-1. or 1-2-3-2. Plus you will more then likly bust up syncros because of the leverage that the shifter has.
I couldn't tell much difference switching from the avid billet inserted mounts to the avid billet solid mounts. I switched to the solid mounts when I installed the shifter.
I spend more time changing parts around just trying things than actually using my car, I never re-adjust anything.
If you haven't already, you guys just need to drive one of these cars that has this shifter. You will see their worth real quick.
thanks for all the input on this. i def think i am going to end up getting one before the season starts.
even if i dont NEED it i will have it for later on if i step up to a dgo box style gearset
