FWD engine containment device.
Old Nov 22, 2011 | 05:35 PM
MrParks's Avatar
Default FWD engine containment device.
well, its finally here.
FCSRace.com has released its engine/trans oil containment device for ALL FWD type vehicles.
FCSRace engine/transmission containment device made for ALL FWD vehicles with transverse type engines. meets SFI 7.2 specifications and requirements. passes all ballistic and oil containment tests with flying colors. we are currently waiting on associations for final approval and et requirements for mandatory use for cars going xx.xx and quicker.
as most of us know, any catastrophic engine failure is almost impossible to contain, but we believe our design will help tremendously in the clean up process and hope to end the oil down situation we all been facing for many years with fwd drag cars.
FCS has engineered this containment device to capture not just engine oil, but transmission failures as well. the design features quick type tethers for easy installation and removal, oil absorbing pads are completely removable with buttons so no need to purchase another diaper like other mfg "one time use" units. if in such cases the motor or trans or axles break away from an event of a failure, our diaper will save the headaches for track personal and resume racing quickly. we also kept in mind of the street type car which would need to run a diaper on the track but not on the street. so our unit is fully removable after the event, removes quickly and without being a pita.
the truth is, it has been a long road for this device. to design changes to sfi and everything between to make sure it will work on everything and to be functional was quite a challenge. so here it is guys, racers, track owners, and nhra has asked for it and we delivered. hope we can finally finish some events without oil downs.
we will release pictures as soon as we get our approval from NHRA for mandatory use on all fwd cars with a et cap. but to start, here are some teaser pictures.
only sfi cert engine containment device for fwd.
2000f deg heat shield nomex, kevlar with silver shielding.
quick push button interchangeable absorbent padding
compatible all fwd transverse engine assy and platforms
view from under the car, b,d,h,f,k,neon,and new ep3, and dc5 compatible.
view for ground clearance. we use a splitter front design. as you can see it tucks up to the motor. no low hanging material or catch pan needed for this application. nhra approved.
this is a rear top view behind the transmission on a b series. notice it covers the simple mistakes like a axles poping of the case etc.
here is a view of the front side area of the device in which some applications will use a downpipe or header to exit in the oem location. the heat shielding is to prevent abnormal wear and burning of the containment device. and will shield 2000f heat temps. we recommend that if you do run dp or headers under the oil pan it is recommended to heat wrap.
updated pictures.
the containment device is now available at local retailers.
Old Nov 22, 2011 | 05:39 PM
SPOOLINmatt's Avatar
Default Re: Product Release: FCS Releases FWD engine containment device.
pretty sweet! I cant wait to see how it looks installed and how it attaches under everything.
Old Nov 22, 2011 | 05:41 PM
1FASTHF's Avatar
^^ X2
Old Nov 22, 2011 | 06:08 PM
92redhatch's Avatar
Default Re: FWD engine containment device.
Price would be nice. It's about time someone made one
Old Nov 22, 2011 | 06:13 PM
crazes's Avatar
Moderator
please dont put a price. give all the tech information and asks questions. if you want a price pm him directly
Old Nov 22, 2011 | 06:15 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
^^^what him said bawwsss
Old Nov 22, 2011 | 06:55 PM
ek9phantom's Avatar
lookin forward to seeing it installed also
Old Nov 23, 2011 | 07:37 AM
turbo-2nr's Avatar
is it all cloth type or is there an aluminum tray to
in for install pics or poss a video if an install on a civic or integra
Old Nov 23, 2011 | 07:55 AM
cetcivic's Avatar
no one wants to hear the truth
go ahead and bring a couple hundred of those to raceway park..prob sell like hotcakes
Old Nov 23, 2011 | 08:11 AM
SLIM NOTHING's Avatar
im def getting my hands on one of these after i see how the fitment is and so on. as of what i see it looks fantastic..
Old Nov 23, 2011 | 08:46 AM
xenocron's Avatar
Badass!
Pics of it installed would be nice
Old Nov 24, 2011 | 01:35 PM
MrParks's Avatar
Pics up soon!
Old Nov 24, 2011 | 01:36 PM
Dragmania's Avatar
you cant reply to my text jason lol.
Old Nov 24, 2011 | 01:47 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
^^^prob not if you didn't get a reply. Smh
Old Nov 24, 2011 | 01:51 PM
Dragmania's Avatar
jesus i was just busting his ***** man. why does everything i say have to be picked apart.
Old Nov 24, 2011 | 01:59 PM
CO_RaceFab's Avatar
Cause your an *******
Old Nov 24, 2011 | 02:02 PM
Dragmania's Avatar
isnt that the pot calling the kettle black ryan.
Old Nov 24, 2011 | 11:14 PM
MrParks's Avatar
My bad its thanksgiving, and I.do all the cooking! I'll get at you guys tomorrow
Old Nov 25, 2011 | 12:43 AM
rudebwoy's Avatar
I am interested in these also, no requirement but everyone should have one regardless of speed, all engine breaks and spill the same fluids no matter how fast its going. so it should be a requirement for all cars that race on the track. think about it.
Old Nov 25, 2011 | 05:15 AM
Blown90hatcH's Avatar
So you are pushing for a SFI maniditory engine diaper for NHRA on FWD cars?
Old Nov 25, 2011 | 03:20 PM
turbo-2nr's Avatar
^that would be best, i think any heads up or sports man class should have to run containment devices
Old Nov 25, 2011 | 03:59 PM
i think he means, approval for use in situations where mandatory devices are required.
Old Nov 30, 2011 | 05:52 PM
MrParks's Avatar
here are the installed pictures requested. took about 5 minutes.
here is a picture for its coverage vs ground clearance. it will basically hug the entire motor/trans.
completely covers the trans and axles in an event of a blow out or axle sliding out.
2000degree nomex liner and silver shield to prevent burning from exhaust running under the oil pan. k series will not have this problem.
Old Nov 30, 2011 | 05:56 PM
nonvtecallmotor's Avatar
What about downpipes? Can this handle the heat of it sitted on it?
Old Nov 30, 2011 | 06:27 PM
MrParks's Avatar
we all know engine configurations all differ from car to car. especially custom setups etc. we kept this in mind. if there is high heat areas around the teathers we can also make them in full nomex fire retardant fabric. in most cases on fwd cars, there isnt too much variations but we considered every angle.
