fuel pump question
Old Sep 12, 2010 | 06:58 PM
evo8turbo2000's Avatar
Default fuel pump question
i have an aeromotive a1000 fuel pump i wanna make right around 850whp on my turbo set up will this pump be enough or do i need to go bigger ive been gettin the run around frm people.
Old Sep 12, 2010 | 07:19 PM
Garage 808 Hatch's Avatar
Default Re: fuel pump question
At 850 it's will be maxed out, and IMO unsafe. I'm right under that on an A-1000 right now. And the pump has nothing left. 1 more event and it's coming out for an upgrade
Old Sep 12, 2010 | 07:39 PM
str8JDMteggy's Avatar
Dual 044s
Old Sep 13, 2010 | 06:04 AM
em_at_kfi's Avatar
What fuel? gas? e85?
Originally Posted by str8JDMteggy
Dual 044s
That would be plenty for 850 on gas. With two pumps, you also need two inlet filters which takes away from some of the cost effectiveness of this route. So for about the same amount of $, you could do a single Weldon 2015.
A1000:
0 psi - 795 lb/hr
20 psi - 714 lb/hr
50 psi - 557 lb/hr
70 psi - 426 lb/hr
044:
0 psi - 490 lb/hr
20 psi - 445 lb/hr
50 psi - 420 lb/hr
70 psi - 390 lb/hr
100 psi - 350 lb/hr
120 psi - 315 lb/hr
2015:
0 psi - 685 lb/hr
20 psi - 660 lb/hr
50 psi - 615 lb/hr
70 psi - 585 lb/hr
100 psi - 540 lb/hr
120 psi - 500 lb/hr
140 psi - 475 lb/hr
160 psi - 450 lb/hr
Old Sep 13, 2010 | 08:29 AM
B18c1turboedEK's Avatar
We have ran one at 890hp for 2 years.
Old Sep 13, 2010 | 09:07 AM
tepid1's Avatar
On an A1000? What base pressure? What was boost pressure?
Old Sep 13, 2010 | 09:26 AM
Ya no ****. I'm at 96% duty on ID2000's with my a-1000. It just can't pump anymore fuel. At around 840
Old Sep 13, 2010 | 09:39 AM
on c16 1600cc injectors s372 turbo. im guessing car will be around runnning around 35-40 psi on boost so the a1000 should be ok at that boost level.
Old Sep 13, 2010 | 09:42 AM
i just dont want to have problems when im on the dyno id rather be safe than sorry. thanks for the input guys i appreciate it
Old Sep 13, 2010 | 11:11 AM
Its been a while but base was about 50, boost was 45 or so. Was on a turbonetics T76 turbo with a really small back housing.
RATEDX1
Mar 10, 2011 08:19 AM
93grayeg
10
Mar 23, 2010 12:33 PM
blue_hatch
Sep 30, 2007 01:24 PM
Michael Delaney
Jun 17, 2001 06:55 PM
