Fuel cell question?
I'm interested in purchasing a 8 gallon drag race fuel cell from Summit Racing. You can check out the pictures at http://www.summitracing.com. The part number is SUM-290103. The cell comes with 2 -8an fittings on the lower rear of the cell and a -6an fitting on the top for the vent line. My question is were do I route my return line from my fuel pressure regulator to? Can I use one of the two fittings on the lower rear where the sump is? Or do I have to route it somewhere else? All your recommendations will be greatly appreciated. Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">Why not just use one of the -6's on top? That should be plenty for a return line.</TD></TR></TABLE>
if he uses the one up top he wont have one for a vent...
I'm 100% sure you can do it cause i did it.Only draw back i can see is that you have the fuel that was heated up by the fuel pump dumping close to the pick-up but in such a small cell even dumping it up top is close.
Use the -6 on the top for the return, and add another fitting on top for a vent. Get a -6 bulkhead, drill out the top of the cell and the put the fitting there.
That's what I was thinking, but I was wondering if there was a way I could do it without having to drill another hole. Oh well though no big deal I guess.
Samuels
24
Jan 24, 2007 10:06 PM
