I am on to my next project, the fuel cell. I got the car with a fuel cell installed already. I am very sure this will not pass tech pretty much anywhere. So, is there anyway I can get this to pass. Can I build a box around the cell and close off the hole? The other option is to move it to the spare tire well and close it off.
move it to the back, use the dip in the rear to send your feed line out.
build a box or "firewall" as the rule book states to seperate it from the driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">move it to the back, use the dip in the rear to send your feed line out.
build a box or "firewall" as the rule book states to seperate it from the driver</TD></TR></TABLE>
That is probably my best bet.
But can I just build a wall around it the way it sits. All the fuel lines and pump are mounted pretty well.
I can't because my battery is on one side and the charge pipe is on the other.
