Found a SMALL problem with the CRX
Old Aug 5, 2004 | 11:22 AM
B20T CRX's Avatar
Default Found a SMALL problem with the CRX
After doing a leak down test and it was a little high I pulled the head off of the car to get a valve job done. None of the valves seemed all that bad for the performance that I was losing so I started looking at everything else. I found a couple of exhaust leaks but nothing major there either. So I decided to pressurize the intake tract including all the hoses and intercooler pipes. That's when I found there was a real problem.
After seeing this I couldn't believe it actually ran a 12.5@116.
Old Aug 5, 2004 | 11:29 AM
Silverhatch's Avatar
Default Re: Found a SMALL problem with the CRX (B20T CRX)
wholie chit.I havent seen anything like that before. How much were U boostin to break the welds on the intank ? Well its good u found the problem.
Old Aug 5, 2004 | 11:32 AM
T70 civic's Avatar
wow jimbo nice intercooler! Whitey should be able to hook that up in about 10 minutes. I'm glad you found the problem cause we were all scratching our head on the dyno that day. at least it was'nt the motor like we thought.
later Justin
Old Aug 5, 2004 | 11:40 AM
SpeedDreamz.com's Avatar
Default Re: Found a SMALL problem with the CRX (T70 civic)
Looks like it might have began as a stress crack and then the boost opened it up. I wish my problems were that simple.
Old Aug 5, 2004 | 11:48 AM
david@didrace.com's Avatar
Eck. There is a crapload of porosity and contaminants in that weld. Welds, for the most part, are supposed to be stronger than the base metal.
Old Aug 5, 2004 | 11:51 AM
dmotoguy's Avatar
Default Re: Found a SMALL problem with the CRX (10-94-55)
happens on semi's all the time
Old Aug 5, 2004 | 11:54 AM
MikeySpec's Avatar
i broke the welds on my intake manifold like that before
Old Aug 5, 2004 | 02:02 PM
paulzy's Avatar
Default Re: Found a SMALL problem with the CRX (MikeySpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">i broke the welds on my intake manifold like that before</TD></TR></TABLE>
Fast and the furious style?
Old Aug 5, 2004 | 02:45 PM
2point2's Avatar
is that a home-made IC?
Old Aug 5, 2004 | 04:36 PM
AMS MIKE's Avatar
Default Re: (2point2)
Who made that interoocler?
Old Aug 5, 2004 | 05:27 PM
B20T CRX's Avatar
Default Re: (AMS MIKE)
Running 28 psi.
We made the intercooler.
The welding was from when he first started playing with aluminum.
Old Aug 5, 2004 | 05:36 PM
PM-Performance's Avatar
Default Re: Found a SMALL problem with the CRX (paul vang)
damn that sucks. the one guy in your crew was telling me he thought valves were burnt up. thats crazy. good luck to getting it fixed quick , i wanna run you guys at Atco
Old Aug 5, 2004 | 05:43 PM
B20T CRX's Avatar
Default Re: Found a SMALL problem with the CRX (itr206)
How are you going to race if you sell the car on ebay?
Old Aug 5, 2004 | 09:32 PM
4CFED's Avatar
Same thing has happened to me before. No big deal. I'd still hit up the valves and ports while you got the head off. Never hurts to go faster.
Old Aug 6, 2004 | 04:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20T CRX &raquo;</TD></TR><TR><TD CLASS="quote">How are you going to race if you sell the car on ebay? </TD></TR></TABLE>
i doubt it will sell . too many kids with big dreams and no money.
Old Aug 6, 2004 | 04:18 AM
nsxmatt's Avatar
I wondered why you weren't hitting times like you usually do at St. Louis. That would do it
oganiler
May 26, 2017 03:02 AM
jarvis199
Mar 7, 2007 08:32 AM
black7hatch
Nov 4, 2006 01:44 AM
