Flat bottom and Aero gain?
Old Mar 5, 2015 | 11:48 AM
Steeve_Civic's Avatar
Default Flat bottom and Aero gain?
What s the gain on 1/4 with a flat bottom?
Which material and thickness?
Old Mar 5, 2015 | 10:06 PM
Default Re: Flat bottom and Aero gain?
Aluminium should be the lightest, 1 or 2mm?
Old Jan 22, 2017 | 12:17 PM
Any feedbacks?
Old Jan 22, 2017 | 01:08 PM
AZ_CIVIC's Avatar
My opinion is that all it may do is create stability at high mph however I haven't done a flat bottom so I am not 100% sure.
I personally don't think it does anything to make you go any faster really, adding an entire flat bottom will just make the car heavier.
That is is just my opinion.
Old Jan 22, 2017 | 02:59 PM
testify's Avatar
On vacation
I'd use Alumalite over sheet aluminum. That's basically corugated aluminum that is extremely light with extremely high rigidity.
Old Jan 22, 2017 | 07:10 PM
king06's Avatar
Gringotegra probably has the most experience with this, he has a bunch of threads.
Old Jan 22, 2017 | 07:36 PM
Full_Tilt's Avatar
There are definite aerodynamic improvements with a flat undertray. For road racing in a class that allows it, it is a no-brainer. For drag racing, its hard to say if it would be worth the weight.
Assuming youre referring to the car in your sig, trapping at 165mph, I think it would be worth trying. A good place to start would be making a pan for under the engine bay. That is going to be the largest area of disturbed air on these chassis, and wouldnt add too much weight.
Old Jan 23, 2017 | 02:27 PM
DaIll1's Avatar
Originally Posted by Steeve_Civic
Any feedbacks?
Fiber cardboard and speed tape would provide clear answer
Old Jan 24, 2017 | 11:46 AM
FlewByU352's Avatar
This but there is also a carbon/kevlar version that is extremely rigid and even lighter! Though it is around $600 for a 4x8' sheet of it.
Old Jan 24, 2017 | 06:09 PM
NWDyno's Avatar
I used 3 layers of pre-peg carbon, basically just cut it out to the desired shape, then baked it and installed it.
Old Jan 24, 2017 | 09:04 PM
DaIll1's Avatar
ABS sheet?
ABS General Purpose Sheet- Textured Haircell Finish
Old Jan 25, 2017 | 02:00 PM
Thks guys
Old Feb 17, 2017 | 08:22 AM
Full_Tilt's Avatar
ABS is heavy. You would be better off using Alumalite or wood.
the171
Jan 3, 2015 08:23 PM
HondaRacer18
May 12, 2005 05:20 PM
GumballNA
Sep 27, 2004 09:01 PM
