First Build..doing it right the first time
Old Jun 8, 2012 | 07:21 PM
jdmthug's Avatar
Default First Build..doing it right the first time
Well would like to post my build that is underway as we speak it. not my first swap but def my first vtec setup/built motor/turbo setup..blah blah blah..definatey have not slacked on anything in this build..originally supposed to be just a b20v all motor nitrous 12.50 index car..but i caught the boost bug...bad...Started this process around mid late oct and got in a auto accident..so it was put on pause and restarted back in january..ive aquired most of these parts in this time frame..and still obtaining parts..im looking forward to taking this car on the track and seeing what it will do...i have alot of photos of work done and will post shortly..
94 civic cx owned since 07
the setup
head
b16 head with port work done by cnc engine dynamics
omni ti valvesprings retainers
ferrea flat face valves
stock gsr cams
stock itr intake manifold
omni 70mm tb
jegs -12 catch can
vented v/c w/ -12 bung
ls block b18b1
bored,deck,honing,and crankshaft polished all done by my main man HOWARD @ Howards Hotrods
cp 9-8-1 pistons
manley rods
oem itr oil pump
gsr water pump
oem gsr timing belt
cometic headgasket
acl bearings
itr oil pick up
transmission
stock ls trans w/mfactory diff
mfactory shifter bushings
stock axles for now
skunk2 short shifter
act flywheel
competition or clutchmasters stage 5 clutch
stock ignition system
hondata s300 w/boost by gear
xenecron 255 fuel pump
inline pro fuel rail
id 1000cc injectors
summit -6 fuel filter stainless braided lines
turbo setup
pte 6262 70.ar t4 vband-(idk i said it right but you get the point)
inline pro stainless t3/t4 log manifold
tial 44mm wastegate
tial bov
treadstone intercooler setup
2inch charge ic piping treadstone
custom vband 3inch downpipe to 2.5 exhaust with 2.5 qtp e-cutout
custom dumptube
im probobly missing some stuff here and there but its def a ongoing process. a few setbacks here and there along with having to some front end work..but it def looks good how it sits..im looking to finish this year..taking a semester off this summer to finish this project and spend time with son...looking to run in the 11.50 index class may 10.50 class however i know that may require some more things here and there..the competition here on the east coast in those classes are fun and still fits my budget..I have ALOT of GOOD help in my corner and have been a great help to me..Look forward to seeing the rest out there at the tracks..good luck to all..
Old Jun 8, 2012 | 07:26 PM
jdmthug's Avatar
Default Re: First Build..doing it right the first time
heres a few pics
Old Jun 8, 2012 | 07:31 PM
jdmthug's Avatar
fyi to all if you zoom out some you can look at the pics better all taken from a htc windows phone..
Old Jun 8, 2012 | 07:42 PM
trunkluv's Avatar
dope build! stock sleeves?
Old Jun 8, 2012 | 10:08 PM
jdmthug's Avatar
yes definately stock sleeves..i was thinking about sleeving the block but ill save that for another future build..baby steps..
Old Jun 8, 2012 | 10:32 PM
01typerboi's Avatar
great start. good luck w/the build
Old Jun 9, 2012 | 11:15 AM
jdmthug's Avatar
Thanks alot I appreciate it. My favorite part has to be my chromoly crash bar..its the exact same dimensions as the oem one. I wanted some safety and something to mount my fmic to and my boy welded it up for me. I used the ac line on firewall as a spot to mount the catch..no wiretuck will be done but I will clean up the harness some..i like things to be clean and functional..the paint is Eastwood extreme chassis black...takes a pounding to all possible fluids that may spray.
Old Jun 9, 2012 | 11:32 AM
92redhatch's Avatar
In order to do it right the first time you should've sleeved the block.
Old Jun 9, 2012 | 02:59 PM
lvdb-2's Avatar
x2^^^^
Old Jun 10, 2012 | 05:35 AM
jdmthug's Avatar
I agree I should of sleeved the block..but the orignal turbo i had was not this big i was going to use a garret t3/t4 60-1. I was looking for maybe 420 on pump and thats it. Just made the change a few weeks back.we will see what happens.either way it will still move. DSS axles will be in the car by the time WCF 2012 starts.
Old Jun 10, 2012 | 11:09 AM
SP GARAGE's Avatar
Instead of sleeping you can try the CSS system
Old Jun 10, 2012 | 12:51 PM
AllShowNoGo727's Avatar
Don't waste your time with css Block guard system pay a LITTLE bit more and get a real block that can hold 900+ hp no problem.
Old Jun 15, 2012 | 06:58 PM
jdmthug's Avatar
update..received all my tools in order to assemble motor minus the piston ring filer and plastigauges to order the correct bearings..pics will be posted engine bay almost reassembled
-block guard will not be going anywhere near my block.
-trans should be done shortly.
all engine bay parts will be reinstalled this week.all body panels installed also
already trimmed the bumper to accomodate the fmic and charge pipes
more pics to come
Old Jan 1, 2013 | 06:33 AM
HalFastTeg's Avatar
Are not recommended for FI setups. Just sold my full set for that reason.
Old Jan 1, 2013 | 07:28 AM
94lsvturbo's Avatar
CNC werx block FTW
Old Jan 1, 2013 | 10:03 AM
MR.johnson's Avatar
Please explain lol.
Old Jan 1, 2013 | 02:45 PM
HalFastTeg's Avatar
Originally Posted by MR.johnson
Please explain lol.
I was going off:
Here
https://honda-tech.com/forums/forced-induction-16/ferrea-valve-springs-skunk2-pro-1-cams-3028192/
And here.
http://www.ebay.com/itm/Ferrea-5000-...bdfc17&vxp=mtr
I just decided it was probably smarter to use the 6000 series valve if I was building the head anyways. Btw seen Dynotuned in your sig, you in the midwest?
Old Jan 27, 2013 | 02:38 PM
jdmthug's Avatar
****UPDATE*******
ALOT MORE PRODUCTS RECIEVED INSTALLED.
CAR SHOULD BE UP AND RUNNING VERY SOON. BETWEEN SCHOOL,KID,WORK,HAVENT SPENT MUCH TIME ON IT BUT HERES SOME MORE PICS OF WHAT IVE GOT..LONG TIME COMING BUT GLAD I COULD FINALLY FINISH IT UP
Old Jan 27, 2013 | 02:42 PM
jdmthug's Avatar
JUST A FEW MORE PICS. THE SHOT OF MY SON HELPING IS PROBOBLY MY FAVE.
Old Jan 27, 2013 | 02:45 PM
DraginX's Avatar
The Ferrea competition plus series of valve comes in a flat face, maybe he went with them.
Old Jan 27, 2013 | 02:48 PM
jdmthug's Avatar
AND A FEW MORE
Old Jan 27, 2013 | 09:41 PM
artie89's Avatar
Ferrea competition plus series valves do not come flat they come dished. 6000s from a metallurgy standpoint aren't any better than a 5000. 6000s are lighter because they are dished, and in most applications have a back cut where 5000s do not. But on a B series, none of them have a backcut. The Competition plus has the inconel material for high heat in the exhaust side
Old Jan 28, 2013 | 03:02 AM
DraginX's Avatar
I'm just going by what I was told when I ordered my valves. I ordered the 6000 series but was told I could get the flat face in competition plus if I wanted, but they were significantly more.
DC4 Rasta
Feb 22, 2007 07:58 PM
slows2k
Sep 25, 2006 07:25 AM
mattcivic
11
Sep 23, 2004 01:20 AM
8400 rpm
Apr 19, 2002 02:37 AM
VaporTrail
Jan 26, 2002 05:40 AM
