Fire Suppression Systems?
Old Feb 17, 2008 | 04:49 PM
Garage 808 Hatch's Avatar
Default Fire Suppression Systems?
Anyone on here running one? any distributors on H-T for them? which is most cost-effective IYO? Just looking for some help as i need a 5lb system for my crx to run in BOTI
Old Feb 17, 2008 | 05:03 PM
Innes's Avatar
Default Re: Fire Suppression Systems? (rota92)
i can offer you these -- http://stroudsafety.com/HalonSystems.html
let me know if you are interested
Old Feb 17, 2008 | 05:06 PM
Innes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">
Saw those in the catalog not too long ago, since they are all the same buy from James </TD></TR></TABLE>
yeah, stroud recently purchased this company called phoenix fire suppression or something to that effect -- really nice kits
Old Feb 17, 2008 | 06:32 PM
DaveF's Avatar
Default Re: Fire Suppression Systems? (Innes)
make sure the fire suppresant (sp) they use is allowed by NHRA. i know some are not any longer allowed..
i have a safecraft system on my car, prettty simple install. it has 2 nozzles for the engine bay (1 spraying at my fuel cell, the other is in the cowl, spraying toward the intake manifold, then one driver compartment nozzle located on my steering column) the system i have is a "push to activate" type system, it comes with a fixed length cable, so you are kind of limited as to where you can mount the bottle. the pull style system comes with an ordinary cable, so you can pull the casing off the actuall cable, cut it to your liking, and reinsall the wire in the cable housing. with the pull system, you have a much better "area" as to where you can mount the suppresant bottle, because of the cable assembly.
Old Feb 18, 2008 | 07:51 AM
Default Re: Fire Suppression Systems? (DaveF)
wow, thanks for he info guys
Old Feb 18, 2008 | 08:01 AM
Default Re: Fire Suppression Systems? (Garage 808 Hatch)
I was just reading on SFI's website that halon is no longer legal????? due to the EPA etc.
Old Feb 18, 2008 | 11:49 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Anyone on here running one? any distributors on H-T for them? which is most cost-effective IYO? Just looking for some help as i need a 5lb system for my crx to run in BOTI</TD></TR></TABLE>
what class in BOTI?
Old Feb 18, 2008 | 03:21 PM
Default Re: Fire Suppression Systems? (Mikey3000)
Pro import
im gonna get my *** kicked, but oh well
Old Feb 18, 2008 | 03:44 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Pro import
im gonna get my *** kicked, but oh well</TD></TR></TABLE>
is that a new rule? i ran 1 race in the Pro Import class last year and they didn't look for that at tech.
Old Feb 18, 2008 | 06:13 PM
FIRE EXTINGUISHER SYSTEM:
Minimum 5 pound, NHRA-accepted fire extinguishing system permitted.
System must be divided with one nozzle on driver’s side and one nozzle on the engine.
also says interior must be finished with tin work, so no gutted interior??
Old Feb 18, 2008 | 06:25 PM
fast forward driver's Avatar
I just received mine from summitt, 5lb system -saf-lt5aab pull type , simple to intall, comes with two engine nozzles, one driver compartment nozzle.. nhra legal 319.95 plus shipping
Old Feb 18, 2008 | 06:38 PM
Default Re: Fire Suppression Systems? (fast forward driver)
how did you get one for 320? cheapest on online is 515 for a 5 lb with FE 36
n/m i just looked under halon 1301. they have one for 319.95, unfortunately, halon is no longer SFI approved
Modified by Garage 808 Hatch at 7:50 PM 2/18/2008
Old Feb 18, 2008 | 06:42 PM
thats summitt's price , they advertise 10lb system, i googled 5lb, searched , and then checked against summitt, hard to beat there prices,,, they do price match if you can find better deal, just give them web site address to match.
according to rule 9.3 1301 halon is legal... at least from what i read?
Old Feb 18, 2008 | 06:45 PM
yes, but is the system you just bought a halon?? or is it fe-36?
Old Feb 18, 2008 | 06:48 PM
edited last post
Old Feb 18, 2008 | 06:50 PM
underpressure02's Avatar
I also have a safecraft system. It was very easy to install and the customer service was great. I wanted another nossel and another t fitting I called them up and asked how much. They said not to worry about it and shipped the pieces to me at no charge.
Old Feb 18, 2008 | 06:52 PM
this is what i keep reading everywhere
Currently Halon 1211 and Halon 1301 are acceptable agents per SFI Spec 17.1. However, as of January 1, 2008, Halon agents will not be allowed in the field. That means that all certified Halon systems currently in use will expire on December 31, 2007, regardless of the system's manufacture or recertification date. This is in response to regulations set forth by the U.S. Environmental Protection Agency (EPA). Concerns about Halons include their ozone-depleting properties as well as the human health effects (toxicity) when discharged in small areas.
Old Feb 18, 2008 | 06:53 PM
Default Re: Fire Suppression Systems? (underpressure02)
safecraft , ??? I havent seen that yet about not being legal...
Old Feb 18, 2008 | 06:58 PM
safecrafts product may be legal, filled with fe-36, but from all i've been reading they are ousting Halon this year
Old Feb 18, 2008 | 07:06 PM
well, i may be testing summitt's return policy...
Old Feb 18, 2008 | 07:43 PM
evil_eagle's Avatar
Just to let you guys know, it's not mandatory to have the fire suppression system for BOTI pro import class, in the rules it states it's "permitted"
I've talked to Frank about this and he is not making it mandatory as of yet. Although it is a good idea to have it in the car just incase of a fire.
Old Feb 19, 2008 | 11:03 AM
Default Re: (evil_eagle)
so if it is permitted, why write it into the rule, as having a minimum? i just reread it, and see that, but when i e-mailed Frank, he said nothing of not having to have it.
Old Feb 19, 2008 | 12:37 PM
Slapshotnerd's Avatar
A bunch of the drift guys just did a group guy through FireCharger:
http://www.firecharger.com/
Old Feb 19, 2008 | 02:27 PM
tepid1's Avatar
Default Re: Fire Suppression Systems? (Slapshotnerd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slapshotnerd &raquo;</TD></TR><TR><TD CLASS="quote">A bunch of the drift guys just did a group guy through FireCharger:
http://www.firecharger.com/</TD></TR></TABLE>
Firecharger = death....
Co2 is an oxygen displacer. Pull that and your dead instantly.
outdated
Sep 3, 2007 08:37 AM
crxforum
Jul 3, 2007 04:43 PM
.Unknown.
Jul 23, 2005 05:55 PM
ek_99_SiR
Feb 27, 2004 02:37 PM
racecontrol
12
Aug 20, 2003 11:32 PM
