Erick's Racing
Well I don't know how recent the topic has been brought up but last time I remember the only thing I think people knew was a 2.1L GSR motor, 70mm throttle body, some crazy ported secret GSR manifold (doubtful butterflys are in place), TODA Spec D's and stock ignition and Hondata. I don't think the block or any port work or anything else has really been disclosed.
... are you sure eric's still on gas? all i know is you can bet the guy is a crazy good driver and runs an equally crazy suspension setup to cut 1.3 60 foots!!
Erick is still on gas.
At the NDRA events he's classed as having somewhere around 2.2 liters (which they check by pumping).
Head/manifold by Alaniz
Toda D cams
Hondata
Erick has all his piston/rod/crank setups done custom, so I doubt you'll ever get any useful info on that.
And Earl is right on with the chassis. You'll see other guys running similar trap speeds (Mohler, L'Natural, Bisi, etc.), but no one gets out of the hole and through the 1/8th like Erick does.
C_A_T
Toda D cams
Hondata
C_A_T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T »</TD></TR><TR><TD CLASS="quote">
Toda D cams
C_A_T</TD></TR></TABLE>
hes not using toda d's. hes got his own custom cams. hes got an 85mm bore and a 97mm crank
Toda D cams
No, he's using Toda D's. We retuned his car on my dyno after he did the install. The Toda D grind is based on Erick's own custom grind.
AKH/Toda is one of Erick's sponsors and they did a deal to retail his grind.
I wouldn't put too much credence in those bore/stroke numbers either :-)
C_A_T
C_A_T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T »</TD></TR><TR><TD CLASS="quote">No, he's using Toda D's. We retuned his car on my dyno after he did the install. The Toda D grind is based on Erick's own custom grind.
so toda is selling spec d's tailored to erick racings specs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">You can figure 95-98mm crank with very high compression and still runs gas. Plus you won't find a better WORKING chassis in all motor</TD></TR></TABLE>
yea no kidding, him and jotech have THE cleanest cars i have ever seen, quality, cleanliness, laout/arrangement, everything, they are SPOTLESS
I remember a while back, he was featured in a magazine, and they said he was running around the area of 14:1, or 15:1 compression ratio. Might have changed his setup, or told the magazines lies to keep it secret, but thats what i heard.
Well first of all, Erick does his own tuning. He just uses my dyno and I offer a little advice here and there. The guy knows exactly what he wants out of the engine.
Second, I can't tell you anything about his numbers. That's confidential information. Occasionally he will publish a dyno sheet, but usually after he's already moved on to his next engine iteration.
C_A_T
C_A_T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T »</TD></TR><TR><TD CLASS="quote">Well first of all, Erick does his own tuning. He just uses my dyno and I offer a little advice here and there. The guy knows exactly what he wants out of the engine.</TD></TR></TABLE>
thats why i give the guy so much respect, he does it all, build/design/tune AND he can drive! hes got skills
[img]C:\Documents and Settings\Andrew\Desktop\dailydriven\Races\CMI\DSC0 0190.jpg[/img]
i found this timeslip on dailydrivenonline at http://www.dailydrivenonline.c...0.jpg
Modified by Drag_Racer_DRU at 5:11 AM 6/2/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T »</TD></TR><TR><TD CLASS="quote">Erick is still on gas.
C_A_T</TD></TR></TABLE>The 2.2 is open knowledge as it is placed on a sticker put on his car by NDRA. You can find a volume calculator and play with the numbers and figure out his combination. 87 mm (could be less) would be about the largest bore you could run so fill in the blanks and the world can have his combination. That will give you about 1% of his combo
Specifications:
1995 Civic coupe body.
1997 Integra GSR B18C1 engine.
Engine:
Bore: 85 mm
Stroke: 87.2 mm
290 bhp
10,800 rpm redline
Engine management: Hondata
Ignition system: stock
Head: Erick's Racing Engines full competition
Intake manifold: modified GSR
Injectors: RC 440 cc
Throttle body: Erick's Racing 70 mm
Header: Erick's Racing custom 4-1 side exit.
Transmission:
Erick's Racing close ratio 5 speed
4.7:1 final drive
Chassis:
Builder: Nick Tierno (NRS) Las Vegas NV
Firewall back chromoly tube.
1600 lbs including driver.
Engine:
Bore: 85 mm
Stroke: 87.2 mm
290 bhp
10,800 rpm redline
Transmission:
4.7:1 final drive
Chassis:
Erick's is using a 76mm throttle body. Just because he sells 70mm ones, doesn't means he uses it. That info came from either Alaniz or Erick, I don't remember who said it at the time. Unfortunately my micrometer wasn't with me either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blykins »</TD></TR><TR><TD CLASS="quote">Specifications:
Engine:
Bore: 85 mm
Stroke: 87.2 mm
290 bhp
10,800 rpm redline
Transmission:
4.7:1 final drive
Chassis:
1600 lbs including driver. </TD></TR></TABLE>This sounds like 2 year old specs.
Engine:
Bore: 85 mm
Stroke: 87.2 mm
290 bhp
10,800 rpm redline
Transmission:
4.7:1 final drive
Chassis:
