engine builders please help
Old Nov 22, 2005 | 04:10 PM
ying_YANGtwin's Avatar
Default engine builders please help
i have a pistons that are listed at 3.194 at the bore and .957 cc for the top of the piston and my question is can anyone convert that into mm and what compression would that be with a b16 head.
Old Nov 22, 2005 | 04:27 PM
SlowReaction's Avatar
Default Re: engine builders please help (ying_YANGtwin)
81.1276 mm
Old Nov 22, 2005 | 09:02 PM
cptengineer's Avatar
if you go from inches to mm then multiply by 25.4 and opposite then divide.
Comp can be calcualted but please specify stroke and block please.
Old Nov 23, 2005 | 07:04 AM
CompressionFed's Avatar
Default Re: engine builders please help (cptengineer)
Here is a good site for easy conversions.
http://www.vmar.com/java/engine.html
Balor_Gr
Engine Machining & Assembly
Dec 9, 2017 12:24 AM
TGonie
Apr 16, 2013 08:21 AM
Figgy1682
Aug 1, 2007 09:55 PM
kevinoneill
Aug 22, 2003 11:45 AM
Mr. Vapor
Jan 14, 2003 11:23 AM
