Eliminating Vtec Solenoid?
Subscribe
Dec 14, 2012 | 06:35 PM
I was looking at Chris Millers NRG tech civic hatch and i noticed he had no Vtec solenoid? Can someone explain this to me if they know?
I noticed he said he has custom cams and modified rock arms. Does that have something to do with it?
Reply 0
Dec 14, 2012 | 06:46 PM
Re: Eliminating Vtec Solenoid?
http://webcamshafts.com
they are pro series cams from web. they are what we run as well as many others
Reply 0
Dec 14, 2012 | 06:58 PM
No VTEC?? No way!!
Reply 0
Dec 14, 2012 | 10:59 PM
Interested
Reply 0
Dec 15, 2012 | 03:47 AM
There's no need for the vtec function if your engines rpm's never drop below say 5k. So guys with big money and even bigger aspirations modify their heads to lessen the mass of all the moving parts.
Reply 0
Dec 15, 2012 | 04:17 AM
My ferrea rocker arms utilizes a single lobe instead of twin lobes like web.
Reply 0
Dec 15, 2012 | 06:59 AM
Do you have to run web's valve train or can you run any upgraded valve train with this set up
Reply 0
Dec 15, 2012 | 08:22 AM
^^^ Chugger is big ballin! lol
Reply 0
Dec 15, 2012 | 08:56 AM
Quote: Do you have to run web's valve train or can you run any upgraded valve train with this set up
its the WEB Rocker arms that you need for their VtAk killer cams.
Reply 0
Dec 15, 2012 | 09:02 AM
Reply 0
Dec 15, 2012 | 09:19 AM
Quote: He is using vtec. He is utilizing a "cam trigger" kit to actuate it is all. If you look on the front(timing belt) side of the motor, you will see there is a sensor, and wire connected to the bracket. That bolts to the head where the power steering used to. That senses a magnet in the cam gear, and tell the compute what the rpm is. Everything else can be take off of the other side of the motor now. And this kit is more accurate as well.
You're either joking or you need to STOP posting in HT technical forums.
Reply 0
Dec 15, 2012 | 09:44 AM
too much vtak!
Reply 0
Dec 15, 2012 | 10:00 AM
Blink
Reply 0
Dec 15, 2012 | 10:41 AM
Lol, how would the rocker arms lock together without oil pressure from the solenoid? 3k posts, its time to start reading and stop posting.
Reply 0
Dec 15, 2012 | 11:18 AM
hahaha
Reply 0
Dec 15, 2012 | 12:14 PM
Reply 0
Dec 15, 2012 | 01:07 PM
Reply 0
Dec 15, 2012 | 01:59 PM
looks like hes missing top tranny bolt
Reply 0
Dec 15, 2012 | 02:14 PM
i have herd the best way to go is web cams ..with the pads some of the roller setups dont work out
Reply 0
Dec 15, 2012 | 02:43 PM
that's an interesting concept you have there.
Reply 0
Dec 15, 2012 | 09:28 PM
ugh.. two things
vtechjunkie needs to edit his post lol..
and moimotorsports needs a better header.
Reply 0
Dec 15, 2012 | 09:49 PM
No1 totally agree
No2 couldnt agree more
Reply 0
Dec 15, 2012 | 10:08 PM
That was an expensive xs power knock off manifold how are you a knock off of a knock off is that even legal lol
Reply 0
Dec 16, 2012 | 01:26 AM
i hope my new setup is okay with u guys
Reply 0
Dec 16, 2012 | 03:14 AM
I'd also like to see him change his name so vtec was spelled properly, being the vtec expert he is.
Quote: That was an expensive xs power knock off manifold how are you a knock off of a knock off is that even legal lol
In his mind copying a copy cancels everything out and it's an original idea again.
Reply 0
