Ef twin disc question
Old Mar 8, 2014 | 06:38 PM
Ryan97's Avatar
Default Ef twin disc question
I have a Crx with a b series, a clutch master twin disc(HD pressure plate) and a hush performance hydrolic conversion. my question is does anyone have a similar set up and what is your pedal feel and travel like? my pedal is extremely stiff and engages very early. curious if this is something other people are experiencing. the pedal only travels like and inch or two and is stiff enough to make the brake master move.
Old Mar 8, 2014 | 07:44 PM
CO_RaceFab's Avatar
Default Re: Ef twin disc question
the hush kit needs to be reinforced, the twins are to heavy for them... as far as engagement point you either need to adjust the cable and/or install a pedal stop.
Old Mar 10, 2014 | 02:05 PM
Ryan97's Avatar
Thank you, I had planned on reinforcing the kit as well as creating a pedal stop not dependent on the pedal assembly (to try and eliminate additional flex.) I am just curious if other EF owners with a hydrolic conversion and a twin disc have the same results.
Old Mar 10, 2014 | 05:06 PM
13173's Avatar
I have a dual disc in my EF hatch. Converted it over to hydraulic clutch with some backyard engineering. I have it braced up pretty well right now and even still the pedal assembly has some flex to it. I assumed that it would and had planned on bracing it a little more as well as adding a pedal stop.
I plan on bracing it to that bar that runs under the dash and around your legs. The one that is normally rusty when you pull all that junk apart. That should do the trick as far as reinforcing it.
Old Mar 16, 2014 | 07:25 PM
andersen's Avatar
I have a comp twin in my EF hatch but I'm still on a cable tranny. clutch is softer then when I had the stage 5 in there. pedal only needs to move about 2 inches I did make a pedal stop.
Old Dec 9, 2019 | 08:36 PM
forbiddenera's Avatar
edit: way wrong thread I don't know wtf happened
Old Dec 9, 2019 | 08:53 PM
It Wasn't Me's Avatar
Sound like another Infinite Scroll victim, to me.
Disable it. You'll find it in the User CP within "Edit Options."
Shouldn't happen again.
Old Dec 9, 2019 | 08:54 PM
yep. that must've been it. thanks
xxxletdownxxx
23
Dec 11, 2019 03:48 PM
Baldb4thirty
Welding / Fabrication
Apr 26, 2010 05:46 AM
pb16b
307
Mar 4, 2009 03:02 PM
Jwbetley
Dec 14, 2005 01:22 PM
