ef chassy guru's
Old Mar 12, 2012 | 04:52 PM
sanman000719's Avatar
Default ef chassy guru's
ok i replaced the stock rear lca's with the blox, and put the blox rear drags on tonight. my rear sway bar has nothing to hook up to now so are you guys just eliminating it or whats the deal
Old Mar 12, 2012 | 05:09 PM
boosted92snatch's Avatar
Default Re: ef chassy guru's
You dont need a sway bar in drag racing just get rid of it. Thats for stability around turns **** like that....perfectly fine to delete it
Old Mar 12, 2012 | 05:18 PM
hello1320's Avatar
Use it for a strut bar
Old Mar 12, 2012 | 05:20 PM
rear strut bar????
Old Mar 12, 2012 | 05:47 PM
hello1320's Avatar
It was a joke.....throw it in the trash
Old Mar 12, 2012 | 05:49 PM
hello1320's Avatar
Are the lca's aluminum ? If so throw them in the trash also....especially if its an ef
Old Mar 12, 2012 | 05:54 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
why do you say that? just wondering.
the original ones were stock junk lol
Old Mar 12, 2012 | 05:55 PM
but i have done descent with the stock lca's
Old Mar 12, 2012 | 07:02 PM
Martian's Avatar
I used stock. Never seen any reason to change the LCA's. Only benefit would be to lessen unsprung weight.
Old Mar 12, 2012 | 07:04 PM
the reason is the blox isnt the same type of bottom shock that fit the stock lca so i had to go to the blox one
Old Mar 12, 2012 | 07:05 PM
took a ride around the block and wow that thing beat me up lol
rough rider fosho
Old Mar 12, 2012 | 08:16 PM
theidealone's Avatar
I had Blox LCAs. Blew the bushings out almost instantly. Put ES bushings in the stockers, and put them back in...
Old Mar 12, 2012 | 08:22 PM
ok the stock ones didnt accept the fork type of bottom shock mount it accepted the ball and well the blox drags arent like that
Old Mar 12, 2012 | 08:50 PM
So get another set of stock LCAs that are 89+
Old Mar 12, 2012 | 09:08 PM
2point2's Avatar
I'd stay the hell away from blox products if they don't even engineer a hole for a sway bar! How the hell do they market this product? lol
Old Mar 12, 2012 | 09:30 PM
sanimalp's Avatar
$cat /dev/urandom
If the car is an SI, you might want to sell it in the EF forum.. the SI had a larger diameter bar that people that turn when they race like, and it doesn't violate the rules like some other bar choices do. All I am saying is that you are probably looking at a $50 bill.
Old Mar 13, 2012 | 02:27 AM
no sway bar needed for drag racing so its not a big deal.
and no hole for the sway bar isnt the issue there is a hole there its just that the sway bar doesnt match up to work properly ill post pix later to help solve the confusion lol
Old Mar 13, 2012 | 06:46 AM
speeddave's Avatar
what blox suspension did you end up using for the front, the EG with the EG forks?
Old Mar 13, 2012 | 07:16 AM
im still on my ksports for the front at this time but ksport makes a 12k srping for the front
mikeSMASHES
Mar 9, 2013 04:57 PM
Black R
56
Nov 4, 2005 04:44 PM
made in JAPAN
Mar 15, 2004 05:18 PM
ridestrt
May 12, 2003 05:32 AM
