edelbrock throttle
Old Mar 22, 2007 | 06:01 PM
slimjimdanny's Avatar
Default edelbrock throttle
i got a stock throttle body and a skunk 2 pro series intake manifold on my gsr. and i was wondering if i buy the edelbrock throttle body would i feel a big gain..? what is the size or what size is good for my setup.. i got all the basic bolt ons.. stock injectors .. but just wannted to know if 70 mm is too big or too small thanks.. i really need to know by tonight.. cuase im going to buy tonight thanks
Old Mar 22, 2007 | 06:51 PM
civicsi401's Avatar
Default Re: edelbrock throttle (slimjimdanny)
dont go with edelbrock if you use that then you will need to get your ecu upgraded and the edelbrock tb has no warmer on it causeing a real shyty idel untill the car operating temp
Old Mar 22, 2007 | 10:55 PM
Trooper's Avatar
Default Re: edelbrock throttle (civicsi401)
To Clarify, the Victor X throttle bodies do not have a passage way for the IAC motor and they do not have a provision for a MAP sensor.
Old Mar 22, 2007 | 11:09 PM
Default Re: edelbrock throttle (Trooper)
what size should i go with? and what brand? what is the stock gsr throttle body size?
Old Mar 22, 2007 | 11:19 PM
civicsi401's Avatar
what size you go with all depends on what you have done to your motor or what you plan to do turbo/supercharged works better with larger size but if its everyday street car 64mm will be fine
bbk is the best for the buck has all sensor ports can bolt right on with no other mods
dc2king
30
Aug 2, 2008 05:45 AM
nitrofish420
Nov 27, 2007 12:52 PM
RACEPAK
Jan 27, 2007 12:40 AM
1hotcivicSi
Apr 7, 2004 08:41 AM
