e85
Old Sep 19, 2010 | 12:00 AM
hello1320's Avatar
Default e85
What is the main purpose for running e85......WHY!!!
Old Sep 19, 2010 | 12:28 AM
OMG B16's Avatar
Default Re: e85
It smells cool.
Old Sep 19, 2010 | 01:40 AM
rudebwoy's Avatar
Default Re: e85
higher octane, more power less chance of detonation, burns cleaner, cheaper, smells better, easier to find for most of us like me that dont have access to race gas. E85 owns 93 octane in all department.
Old Sep 19, 2010 | 01:51 AM
BoostThisMS's Avatar
Default Re: e85
e85=105octane..
and it only costs 2.59 a gallon here.. where as race gas is over 8 dollars a gallon.
Old Sep 19, 2010 | 04:22 AM
fourthchirpin's Avatar
Default Re: e85
it burns cooler so you can actually advance timing a good amount in any given application.
Old Sep 19, 2010 | 04:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: e85
only downfall that i know of, (i have no exp running it) i have read about in consistencies from station to station.
Old Sep 19, 2010 | 05:10 AM
HondaKyle's Avatar
Default Re: e85
Can I fill on up E85 at any gas station as long as its the same type and brand? (use any shell 93 now) Does it burn twice as fast? I heard a full tank is like having a half tank.
Old Sep 19, 2010 | 06:11 AM
katch24's Avatar
Default Re: e85
lower EGT's.......
Old Sep 19, 2010 | 06:13 AM
SPOOLINmatt's Avatar
Default Re: e85
up north it can switch to e70 in the cold months, and most stations dont know when it is changed over so dont bother asking lol.
Old Sep 19, 2010 | 06:55 AM
TDautowerkes's Avatar
Default Re: e85
cause you can make over 1100hp with it!
Old Sep 19, 2010 | 07:04 AM
OMG B16's Avatar
Default Re: e85
If you stalk the gas station and catch the guy who is pumping it from the truck, he has a mix sheet from when he picks it up. Atleast the guy i ran into down here in FL filling our local e85 station did.
Old Sep 19, 2010 | 11:55 AM
Ls_dx's Avatar
Default Re: e85
I wish there was an E85 station here
Old Sep 19, 2010 | 12:36 PM
HondaKyle's Avatar
Default Re: e85
I dont drive the car in winter or cold months. What about next year? would I need to have it tuned all over again?
Old Sep 19, 2010 | 01:02 PM
Default Re: e85
no retune, just gotta wait til the warm months to get fuel.
I get mine from a private pump that always has e85....unless the temp falls below 0, which this is GA and will just about NEVER happen.
Old Sep 19, 2010 | 02:25 PM
Boosted-EH-804's Avatar
Default Re: e85
I have been looking into e85 but we dont have it local. Seems to be a bitch trying source it by the drum. I think it is a good and cheap alternative to some race gas'. Does anyone here buy it by the drum. Sorry for the thread jack.
Old Sep 19, 2010 | 03:40 PM
rudebwoy's Avatar
Default Re: e85
you can always buy one those e85 monitors from zietronix, the best affordable wideband now has a e85 monitor to tell you what percent of ethanol you are running, kinda pricey though. http://www.zeitronix.com/Products/ECA/ECA.htm
Old Sep 19, 2010 | 04:45 PM
hello1320's Avatar
Default Re: e85
I know its cheaper....but u have to use more to make the same power as gas???? And I heard something about some additives u have to run in the oil.....
Old Sep 19, 2010 | 05:16 PM
MadnessRacing's Avatar
Default Re: e85
I dont know about that but Ive been using E85 for over a year and it has been very consistant.
Sure! but you will need big injectors!
Old Sep 20, 2010 | 02:49 PM
HondaKyle's Avatar
Default Re: e85
After asking a few questions and reading other peoples, I hope E85 gets more popular. I wasnt to sure about it untill now but ill def look into it for future use!
Old Sep 20, 2010 | 02:53 PM
Turbogixxer's Avatar
Default Re: e85
At least in the south, it is more consistent then pump gas(93).
E85 is awesome as long as you have the fuel system and ignition system for your goals.
Old Sep 20, 2010 | 02:54 PM
Default Re: e85
It will make more power.
It matters how the motor is built and tuned. I would change the oil more often on e85.
Old Sep 20, 2010 | 10:50 PM
V-SPEC 1's Avatar
Default Re: e85
How long would the wideband last running e85? I know running leaded fuel decreases the lifespan of the sensor any idea?
Old Sep 21, 2010 | 01:04 AM
jv88_dc2's Avatar
Default Re: e85
Sorry to thread jack, but should i "convert" from Shitty CA 91oct to e85? Is it worth it?
Motor is a b20vtec, RS machine slugs, p72 head, JUN3 cams, weekend warrior, blah, blah..should make over 220whp
Any answers?
Old Sep 21, 2010 | 02:57 AM
josh green's Avatar
Default Re: e85
Would it burn cool enough to be able to run a tighter p2w on say 800+hp?
Old Sep 21, 2010 | 05:31 AM
V-SPEC 1's Avatar
Default Re: e85
good question.
