Drum vs disc
Old Apr 13, 2012 | 06:52 AM
jazzRS's Avatar
Default Drum vs disc
I am in the process of building an all motor street/drag car and was curious on the benefits or downsides or retaining rear drums. I know disc has better fade resistance but seeing as how this is a drag car I don't think that will be an issue. I believe drums to have less rolling resistance and weigh less than disc. What are you guys running in the way of rear brakes? This is not a track only car but not a dd either. It will probably be driven once a week, to the track or on nice days to cruises or what not
Old Apr 13, 2012 | 07:03 AM
Innes's Avatar
Default Re: Drum vs disc
Drums and they stop the car just fine -- the vast majority of people will not even notice a difference in stopping power between Disc and Drums
Old Apr 13, 2012 | 07:04 AM
zakura R's Avatar
Integra Real disc conversion in here
Old Apr 13, 2012 | 07:17 AM
Smokalicious's Avatar
i run drums with a staging brake and keep the stock ebrake for parking
061000rr's Avatar
went from a integra with rear disc to a eg with drums and damn near went into the sand pit cause i couldnt stop. but thats at our local tracks. trapping around 135-140. in the integra with was full weight i could hit the brakes late and still have to let off to get to turn off. i felt a HUGE diffrence.
Old Apr 13, 2012 | 07:41 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Disc are 7lbs heavier than drums on each side but I ditched the drums for rear disc of a teg.
Old Apr 13, 2012 | 07:58 AM
JayWest's Avatar
Switching out my disks for drums very soon
Less weight and no problems stopping, especially for an all motor car
Old Apr 13, 2012 | 09:05 AM
Hyper16-Johnny's Avatar
To stay safe and to be able to stop, instead of ditching the rear discs, why not go with the Fastbrakes big brake Drag setup. For those who are worried about weight, it saves about 15lbs per side in the front. Here's the link http://www.fastbrakes.com/category_s/91.htm
Old Apr 13, 2012 | 09:51 AM
jazzRS's Avatar
forgot to mention i plan on running all motor too. 2.0 gsr in a mildly gutted ek hatch. i ordered a 98 accord wheel cylinder to compare to a 98 civic wheel cylinder today. bore on the civic is 3/4 and accord is 13/16. mounting points, length, width etc is the same so i plan on running the accord wheel cylinders with porterfield pads since they are the only people who make aftermarket shoes for the drums. i think that should be sufficient for an all motor car in the 11s
Old Apr 13, 2012 | 09:58 AM
92redhatch's Avatar
Went from drums to discs and it made a huge difference. I wouldn't go back. It's a turbo car
Old Apr 13, 2012 | 11:10 AM
Divers's Avatar
Drums will never drag. Thats the biggest benefit I see.
I'm suprised to hear people have troubles stopping with drums. We stop from 170+ with no rear brakes at all and stock ex rotors with cx calipers up front. No problems.
Old Apr 13, 2012 | 02:43 PM
SonicRacing1's Avatar
I don't see any number to call fast brakes maybe im missing it help?
Old Apr 13, 2012 | 03:13 PM
hondaracing84's Avatar
I run no rear brakes. Front only running off the pedal.
I have a kens kustom booster delete kit and its T'd off to the fronts only. The rear brakes are controlled by a staging brake and are only used for the burn out and to stage. As far as stopping, I have no issues what so ever with fronts only and Im trapping 140+mph. Oh, and they are stock diameter civic cx brakes. Stock caliper, semi matalic discs and summit drilled and slotted rotors.
So, if I can stop just fine with no rear brakes off the pedal, you should have no issues stopping with rear drums in addition to your normal fronts.
Old Apr 13, 2012 | 03:25 PM
jazzRS's Avatar
Good stuff. Thanks for the experiences an insight. Glad to have a thread with quality discussion. Seems rare around these parts
Old Apr 13, 2012 | 03:52 PM
jdm inc's Avatar
integra front back and rear disc brakes cause its a si chassis.
stopping at 155 no problem.
imo i would just keep the drums and put the money else where.
Old Apr 14, 2012 | 08:01 AM
jazzRS's Avatar
yep thats the plan. i want an ek hatch but if i end up with something with disc ill keep them, if i end up with the hatch with drums, ill keep them too
Old Apr 14, 2012 | 08:35 AM
Scroll down and click on "Company Info."
Old Apr 14, 2012 | 08:30 PM
SkunkedRex's Avatar
Lol. Look at tony,of T1. That integra is drum. Just my 2 cents
Old Apr 15, 2012 | 08:13 PM
2point2's Avatar
maybe it depends on the weight of the vehicle? or maybe people are buying their brake parts at harbour freight?
I had no issues stopping a 140mph crx with crx hf rear drums.
mikeymike413
Suspension & Brakes
May 22, 2022 12:18 PM
Moms 94
Suspension & Brakes
Jan 7, 2013 10:21 AM
mechanix619
Suspension & Brakes
Nov 7, 2008 07:05 AM
Race Egr
Jan 12, 2005 03:22 PM
reallycooleg
18
Oct 1, 2004 08:10 PM
