Drag suspension setup
Old Jul 23, 2007 | 01:07 AM
JDM97R's Avatar
Default Drag suspension setup
Hi guys, I have a turbo ef civic with about 500 whp.and i have a big big problem with traction.My current suspension is Skunk 2 drag launch with energy suspension bushing and as i use it for the strip i have the drag slicks mt 26/8.5/15. (see my garage)
Can somebody help me which suspension i have to use to improve traction and also i have a jdm 96 spec tranny with the 4.4 fd
Thanks
Old Jul 23, 2007 | 01:44 AM
Richard...'s Avatar
Default Re: Drag suspension setup (JDM97R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97R &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, I have a turbo ef civic with about 500 whp.and i have a big big problem with traction.My current suspension is Skunk 2 drag launch with energy suspension bushing and as i use it for the strip i have the drag slicks mt 26/8.5/15. (see my garage)
Thanks
not sure what else you have but motor mounts traction bar LSD all help along with your quest for better traction!
i also have the skunk2 drag springs with the AGX shocks + the above obviously your making FARrrrrrrrrrrrrrr more power then me however should be a good starting point!
Old Jul 23, 2007 | 01:18 PM
JDM97R's Avatar
Default Re: Drag suspension setup (richard7968)
I have already an lsd ,Hasport motor mounts and traction bars on the way.Some other ideas please?
Old Jul 23, 2007 | 04:21 PM
reactone's Avatar
Default Re: Drag suspension setup (rota92)
Limit your suspension travel up front
Old Jul 25, 2007 | 12:22 PM
extremevtecracing's Avatar
Default Re: Drag suspension setup (reactone)
Limit straps help eliminate the up travel of the front end.
Old Jul 31, 2007 | 08:23 PM
dday00si's Avatar
Default Re: Drag suspension setup (extremevtecracing)
omni
Old Jul 31, 2007 | 10:17 PM
BlakeJ53's Avatar
Default Re: Drag suspension setup (dday00si)
Not to thread jack, but were can I get some limiting straps and were do they mount on the front of the car?
Old Aug 1, 2007 | 07:49 PM
NABeastRR's Avatar
Default Re: Drag suspension setup (BlakeJ53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack, but were can I get some limiting straps and were do they mount on the front of the car?</TD></TR></TABLE>
Old Aug 1, 2007 | 08:21 PM
bottlefed93civic's Avatar
what is the spring rate on the front and rear? what are u launching at and what is the tires pressure?
Old Aug 2, 2007 | 02:38 AM
JDM97R's Avatar
Default Re: (bottlefed93civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefed93civic &raquo;</TD></TR><TR><TD CLASS="quote">what is the spring rate on the front and rear? what are u launching at and what is the tires pressure?</TD></TR></TABLE>
I have 900 rear .I launch with 6000rpm and tyre pressure set to 10psi (cold), but my problem is also on second gear.I have all the second gear spinning
Old Aug 2, 2007 | 12:29 PM
do you do a first gear or second burnout? you have a good spring rate . i wud think ur tires are not getting heated up enough
GREEN
Old Aug 2, 2007 | 01:45 PM
katch24's Avatar
Default Re: (rota92)
what rota92 said. take some boost out of 1 and 2
good luck
Old Aug 2, 2007 | 02:36 PM
JDM97R's Avatar
I am doing a 2nd gear burnout. I have the hks evc pro boost controller but don't know if i can set a gear dependent boost
Old Aug 2, 2007 | 02:44 PM
JDM97R's Avatar
I just bought then from summit about 2 months ago.I think i can do a 3rd gear burnout but i have a single plate clutchmasters stage 5 and i think it would spin the clutch
Old Aug 2, 2007 | 02:47 PM
Boostfed's Avatar
New User
Sorry to get off topic but do you know my customer Marlon Mifsud? It has been awhile since I have heard from him
Back on subject , I have a strange feeling that your track in Malta may not be prepped very well either. Do they put VHT down on the track? Do the other say RWD cars hook up there well?
Old Aug 2, 2007 | 02:57 PM
JDM97R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt worry so much about that, what RPM are you launching at? Any anti-lag?
What are your ET's and traps, 60's and 330's if you don't mind my asking?</TD></TR></TABLE>
My et 10.66, traps 136.86 and 60's 1.89.Ihave no anti lag as i use apexi power fc.I launch at 6000rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to get off topic but do you know my customer Marlon Mifsud? It has been awhile since I have heard from him
Back on subject , I have a strange feeling that your track in Malta may not be prepped very well either. Do they put VHT down on the track? Do the other say RWD cars hook up there well? </TD></TR></TABLE>
About Marlon i know him well i Have built his engine,he sold his itr and he has a s2k on his mind.About the strip,the rwd hook well and they use some vp stuff for the track
Old Aug 2, 2007 | 03:02 PM
JDM97R's Avatar
Yes it's spins all the way to the starting line.Can it be my clutch is going bad?
Old Aug 2, 2007 | 10:00 PM
JDM97R's Avatar
I set my tyre pressure at 10 psi (cold)
Old Aug 3, 2007 | 03:21 AM
DaveF's Avatar
Default Re: (JDM97R)
you need to drop the pressure in the tires....
7.5 sounds good !
Old Aug 3, 2007 | 08:00 AM
JDM97R's Avatar
I'll try to drop the tyre pressure at 7psi and see what she can do
Old Aug 3, 2007 | 08:33 AM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97R &raquo;</TD></TR><TR><TD CLASS="quote">I'll try to drop the tyre pressure at 7psi and see what she can do</TD></TR></TABLE>
yeah 10psi is pretty high on slicks not sure what people are doing with the moster truck 26's though. is it just me or does 6000 seem pretty low to launch too. especially with no antilag.
Old Aug 3, 2007 | 08:45 AM
katch24's Avatar
that should help your ET we run 6-8 psi (with tubes)
most of the time around 6psi.
omni was the best set up for us, and the price is not that bad.
Old Aug 3, 2007 | 09:14 AM
DaveF's Avatar
Default Re: (mike@synapse motorsport)
nevermind./
Old Aug 3, 2007 | 10:27 AM
i agree with dropping the trie pressure. 6000 is not a bad launch point at all depending on what you are shifting at. just try what they were saying and drop the pressure than heat up the tires real well and go for it.
Old Aug 3, 2007 | 10:30 AM
DaveF's Avatar
how does launch rpm have anything to do with shift rpm ?
