Drag radials
Old Mar 27, 2006 | 04:00 PM
Blueallie's Avatar
Default Drag radials
How many tenths do drag radials normally knock off 60ft times? The best Ive been able to muster is a 2.333. I mostly get 2.4-2.6 depending how much wheelspin I get. Rightnow It spins all of 1st and half of 2nd. I launch at idle.
Thanks for the help in advance
Old Mar 27, 2006 | 04:04 PM
james111's Avatar
Default Re: Drag radials (Blueallie)
type of d/r
car
redline
may help
Old Mar 27, 2006 | 05:04 PM
Blueallie's Avatar
Default Re: Drag radials (james111)
Iwas thinking about bf goodrich 205/50/14. Crx si w sohc zc i/h/e
Old Mar 27, 2006 | 05:15 PM
james111's Avatar
205-50-15 at 12psi
only way to go..
i went 1.71 60' launching at 4.5k-5k
was boosted though, stick with bfg's not 14's
Old Mar 27, 2006 | 05:58 PM
Blueallie's Avatar
Arent 15's heavier than 14's or 13's more recipricating mass? Plus the bigger tire
='s more weight. Wouldnt that slow me down?
Old Mar 27, 2006 | 06:23 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blueallie &raquo;</TD></TR><TR><TD CLASS="quote">Arent 15's heavier than 14's or 13's more recipricating mass? Plus the bigger tire
='s more weight. Wouldnt that slow me down?</TD></TR></TABLE>
Not at all. If a larger tire allows you to cut better 60's (even like 2.1 60's) you'll shave over .5 sec. off of your current E.T.'s cutting 2.4+ 60's . You need to practice and try different tire pressures. I've cut 1.8 60's on 225/50 BFG's and 2.0's on Straight Kuhmo Ecsta street tires.
Phil
EDIT: I'd suggest the 205/50/15 BFG at lower psi (10-14) for you as well. They like lots of heat so, keep that in mind
Old Mar 28, 2006 | 01:33 PM
Blueallie's Avatar
Default Re: Drag radials (hondaguyef)
thanks
accord99power
Oct 9, 2009 05:50 AM
97grnrs
Mar 14, 2008 08:15 AM
Honda_Tengoku
Mar 17, 2005 02:19 AM
1SIKCRX
Aug 26, 2004 02:26 AM
DarkSol97
Sep 26, 2003 02:24 PM
