Drag Radial secrets question
Old Jun 27, 2009 | 04:15 AM
RICE POLICE SIP's Avatar
Default Drag Radial secrets question
Ok, I'm a little frustrated after tonight at the track. It was my first time with my new MT 205/50/15 DR's... I've hit a 12.1 @ 116 with my 24.5" M&H slicks... Now with the same setup but with my DR's I hit a best of 13.8 at 108.. Now it doesn't help that it is warmer now then before and that my tranny isn't in the best of shape but I didn't miss shift or anything.. The car has 316WHP...
I started with the tire pres. at 11psi and with me boosting only 8psi (low boost) I spun out of the whole and a little in second... so I dropped the pres. to 8psi in the tires and went to high boost (18PSI) and I did even worst... best 60ft of the night was a shitty 2.2
How do you guys with DR's do it? Do I have to learn how to drive with them like I did with the slicks? Anyways.. any help would be greatly appreciated! TIA
Shane
Old Jun 27, 2009 | 03:41 PM
Default Re: Drag Radial secrets question
any help or pointers?
Old Jun 27, 2009 | 06:59 PM
bigb16's Avatar
DR's should get you better than a 2.2 60'. My best advice is to slip the clutch a little bit longer to avoid bogging or spinning. I have pulled a 2.13 on 205/50/15 cheap all season street tires. Slip at 4500rpm then move up if it feels like boost takes too long to come in. Are you preloading with the handbrake? I think it helps keep the launch rpm more consistent if you do.
Old Jun 27, 2009 | 07:12 PM
BoostR41's Avatar
tires are too small first off. 225/50 is what you want. next just practice practice practice and mess with tire presure. my best 60 on a DR was 1.89 best on bias ply DOTs 1.74
Old Jun 27, 2009 | 07:53 PM
Kevin's Avatar
Gonna need to get a handle on boost control per gear.
Old Jun 27, 2009 | 08:08 PM
tagperformance's Avatar
wrong type of drag radial cause it doesn't have a soft sidewall or a wrinkle wall effect. You might want to look into purchasing some M&H or Mickey thompson radials. They would be better suited for your power levels with a turbo car.
Old Jun 27, 2009 | 10:28 PM
dustin528's Avatar
try to run a little more pressure... I run from 14 to 25 psi when i use my dr's. Try slipping the clutch if you aren't. Don't floor it immediatly, let it hook a little then get in it all the way.
Just suggestions, they might not work for you. I haven't ran dr's at the track in about 2-3 years... haha I went slicks and never went back.
Old Jun 27, 2009 | 10:30 PM
MindLess311's Avatar
why would you go from slicks to drs?
Old Jun 28, 2009 | 02:48 AM
EddieCRX's Avatar
This is me running a 12.3 in the far lane
http://www.youtube.com/watch?v=G36fWKBpDjg
Drive the car to and from the track, completely road legal
Full interior, glass windows, electric sun roof, electric windows, more or less how it left the factory.
I run MT 225/50/15 drag radials @12 to 14psi
B18 (forged) ITR head and valve train
GT30, ram horm @10psi (boost will be incresed at some point)
JDM Y1 transmission with quaife diff
I launch in 2nd (see vid) and manage 2.0 60fts, reason being I get 1st to 2nd changes less than 50% of the time, what I loose in the 60 I make up for in the 330, using poly inserts as I hate solid mounts for the road, will look at running engine torque damper/s up top the revert back to 1st gear launching.
At some stage I’ll work out how to use launch control etc and drop into the 11’s, I feel it best to learn how to drive the car without the electronic aids at the beginning, would love to run a low 11 high 10, be a dream, and slicks will happen at some stage.
Old Jun 28, 2009 | 12:06 PM
dustin528's Avatar
If you are spinning and revving high, i'd try not shifting fast into 2nd. My car won't shift fast while i'm spinning at all! I am revving to 10k though. I would still always just launch in first though. Do a good burnout!!
b16hybridsol
Sep 29, 2011 03:17 PM
accord99power
Oct 9, 2009 05:50 AM
EJtypeR
Jun 21, 2005 11:00 AM
tinkerbell
Dec 18, 2003 11:20 AM
TuRbO_CrX_7o2
May 7, 2003 02:28 AM
