drag radial question
Old Apr 24, 2017 | 05:10 AM
Bsracing78's Avatar
Default drag radial question
I have a 97 civic coupe with a k-swap. it made around 280 hp on the dyno. i want to get drag radials but need advice on how big i should go, and what will fit. any info and pics of tires on cars would help. please let me know rim size and offset, tire size, 60' times, and where to purchase.
Old Apr 24, 2017 | 05:57 AM
Liamtelfer's Avatar
Default Re: drag radial question
I need a the same question answering Pal, Im running a Ek b18c4 350whp, here in the uk im running Toyo Track tires for the strip and spin in every gear, ive been told to get MT 26.0/8.5R15 pro drag radail, But am unsure on what 15" rim would accommodate these the best, dont know what 15" standard steels would be like ?
Old Apr 24, 2017 | 06:05 AM
Bsracing78's Avatar
26x8.5 sounds a little too big for 350 hp. but i would guess you'd need 8in rim with 20mm offset for that tire. i hope someone with a little more experience than myself will chime in.
Old Apr 24, 2017 | 06:15 AM
Liamtelfer's Avatar
Trouble is ive spent alot of money on Brake set-up with 286mm Fronts so i am limited to 15-16" rims, seems to be MT and M&H have loads of 15" Radial options, think 26-8.5 is the smallest they do
Old Apr 24, 2017 | 06:32 AM
AZ_CIVIC's Avatar
MT has a 225/50/15 if you don't want something too big. OP if you are at the track and want to hook, why not use slicks?
Old Apr 24, 2017 | 06:49 AM
Bsracing78's Avatar
good question. i have considered slicks, and i might go with that. i've never done much with drag radials and figured it would be fun to drive the car to the track and drive it home the same way. assuming i don't break anything. lol
Old Apr 24, 2017 | 07:24 AM
Liamtelfer's Avatar
ET Drag Radial ? Mickey Thompson Tires & Wheels
Old Apr 24, 2017 | 08:00 AM
Lewthepimp's Avatar
Originally Posted by Liamtelfer
PM'd
Old May 8, 2017 | 02:43 PM
superfly_jdm's Avatar
AT 350hp, A 225/50/15 would be more ideal. This setup equates to somewhere around 24.5" slick. There are plenty of steel wheels with the correct backspacing and width to accommodate this size correctly around $50 a piece on ebay. I found a SET(4) of steel wheels in the correct bolt pattern for $30 on facebook! It's just a matter of searching. I got lucky because my bolt pattern (5x114.3 AKA 5x4.5) is widely used in alot of lifted trucks and larger cars.
93bubble87
Sep 14, 2010 11:35 AM
killerpenguin21
May 28, 2009 05:55 AM
PACT man
Nov 19, 2007 02:29 PM
95ejjj
Jun 9, 2005 05:58 AM
SlicksMH
Dec 12, 2004 05:38 PM
