double flare tool
for those of you who have relocated or redid your brake lines, did you use a metric double flaring tool? if so, where did you get it? im having trouble looking for one. thank you. or does the standard 3/16" flare get the job done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">for those of you who have relocated or redid your brake lines, did you use a metric double flaring tool? if so, where did you get it? im having trouble looking for one. thank you. or does the standard 3/16" flare get the job done?</TD></TR></TABLE>
standard worked fine for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">i was using a double flaring tool, i wanted to know if anyone has used the standard 3/16" instead of buying a metric sized one. i would never use a single flaring tool</TD></TR></TABLE>
I only use a double flare as well, and yes SAE works fine. All my brake/clutch hardlines are done this way.
DOHCgarage919
Oct 8, 2007 04:38 PM
