does this look right?
Old Sep 24, 2010 | 09:06 AM
061000rr's Avatar
Default does this look right?
502whp 24.5x8x13 mt. 6 point chromoly cage in a 93 hatch. everything in car but pass seat and rear seats.
1.610 60ft
4.691
7.107 1/8th mile
100.80mph
10.944 1/4
132.167mph
Old Sep 24, 2010 | 09:15 AM
pellis90's Avatar
Default Re: does this look right?
Does not look half bad.
Old Sep 24, 2010 | 10:32 AM
xenocron's Avatar
About right...did you scale the car at the track? Should weigh 2400-2500 lbs with driver...
Old Sep 24, 2010 | 11:21 AM
base-op.1320's Avatar
Stock ls rods and pistons -500whp on 93?
Old Sep 24, 2010 | 12:35 PM
061000rr's Avatar
yep. arp rod bolts. only thing i did to the bottom end.
Old Sep 24, 2010 | 01:31 PM
061000rr's Avatar
have not scaled it.
i just dont get how i had the same setup in a 94 integra w/o a cage and only 378whp and ran a 11.1. i took everything out of the integra and put in my hatch went from a gt35r to a 4088 picked up 125whp and only knocked off 2 tenths?
Old Sep 24, 2010 | 02:06 PM
93-lsvtec-eh2's Avatar
you changed your power band therefore your traction changed in every gear and so on
Old Sep 24, 2010 | 02:51 PM
dustin528's Avatar
Looks pretty dead on to me! here's mine. Not for sure what my car made cause i street tune it myself, but anywhere from 400-450whp on 14-15psi. It weighed 2470 with me in it.
Old Oct 20, 2010 | 06:39 PM
061000rr's Avatar
finally found a video of the run. since then i tried my friends 24.5x9x13 that are prob just as old as my slicks and ran a 10.74 at 135.5 on my first run then i broke it!!
http://www.youtube.com/watch?v=KN-tqadUQSo
Old Oct 20, 2010 | 06:58 PM
j-bird20's Avatar
sounds like it hit the limiter in 1st pretty hard,try to control that. you might be able to ride out 1st alil more. also sounds like it bogged down on the 1-2 shift. its hookin 2nd pretty good, see if u can put alittle more power into it.
Old Oct 20, 2010 | 07:11 PM
061000rr's Avatar
if you watch at the top of second a bunch of smoke can out, thats where i tried to give it more a blew the tires off. as far as out the hole the dude took forever to drop the light so it was at like 12-13psi out the hole. but yeah i did shift to early to 2nd cause it fell out of boost. i have only been on this hp at the track maybe 5 times. so i got alot to learn
Old Oct 20, 2010 | 07:14 PM
Poootie's Avatar
MPH seems a lil low in the 1/8th..
this is my slip on wastegate (15psi) on a 81mm/9.7:1 GSR w/ Ls crank and rods.
Old Oct 20, 2010 | 07:34 PM
sanman000719's Avatar
what ems is this car on??????
also you guys are trapping more than me in the 1/8th but im crushing it on the big end not to mention them 60' times are what i dream of
Old Oct 20, 2010 | 07:39 PM
061000rr's Avatar
chrome
Old Oct 21, 2010 | 05:16 AM
ahhh thanx
Old Oct 21, 2010 | 05:32 AM
DeLucia's Avatar
Times seem spot on
Old Oct 21, 2010 | 06:43 AM
BoostR41's Avatar
Originally Posted by 061000rr
have not scaled it.
I did almost the same thing. went 11.0 in the teg with 556whp and 24.5x8.5x15 slicks, swapped to a 92 hatch retuned and made 583whp and put on 24.5x8x13 slicks and went 11.3 with the same trap in both cars. That is why I am swapping everything back to the Integra chassis.
Looks pretty spot on on the slip though. I wish I could pull a 60ft like that in my hatch. You're 1/8 MPH looks good too
Old Oct 21, 2010 | 06:49 AM
gringotegra's Avatar
We are "Hooking" hard in the first half thats why 1/8th trap goes up ...I went 106.4mph in my 10.6@137 pass....
Pootie, damn man that track is good! haha
Over the years ive noticed, the more you hook the higher the 1/8th mph is...I can trap the same on street tires and slicks but my 1/8th mph is always down 4-5mph and i shift 4th After the 1/8th...
Old Oct 21, 2010 | 07:15 AM
Poootie's Avatar
Yea man . i guess i'm spoiled being 40 minutes from Etown.
Old Oct 21, 2010 | 08:29 AM
Damn you are spoiled! I wonder what a street tire pass on that track would feel like!
Old Oct 21, 2010 | 02:30 PM
Poootie's Avatar
i went there OPENING DAY one year. I was literally th 5th car on the track for the year. NOOOOOOOO RUBBER DOWN, the track was a natural color.
i spun the wholeeee track.... i assume thats what a poorly prepped track in other areas feel like?
Old Oct 21, 2010 | 02:45 PM
Ls_dx's Avatar
Icon3 Re: does this look right?
Precisely
Old Oct 21, 2010 | 02:58 PM
actually im thinking my ems is jacked lol my tuner tried to get it dialed in also on the track and we never got it on the launch it would fall to far back in rpm and take to long to come up on boost
thinking about going to Hondata
Old Oct 21, 2010 | 04:23 PM
061000rr's Avatar
yeah there is nothing more frustrating then having something that doesnt work! i hate chrome but at the moment i cant afford to switch cause i cant afford to have to retune the car. im kinda stuck between hondata and the rtp demon board setup. hondata has def proven therself but its just seems like with all this new stuff that they are out of date? i havnt seen anything new from them in a while
PSI GUY
Oct 3, 2014 08:55 AM
stackz
Jan 24, 2012 02:12 PM
kcjohnnyboy
Oct 17, 2005 07:15 PM
blkcoupe94
Jun 3, 2005 06:28 PM
MYDA9
Dec 20, 2004 02:20 PM
