DD with a1000 pump ?'s
Old Aug 25, 2008 | 06:21 PM
zex_cool's Avatar
Default DD with a1000 pump ?'s
i just got a shell with a1000 pump, -10an feed lines and etc. i DD all of my cars and this one wont be any different. does anyone else drive there cars on the street with this pump? how long to they usually last? can you do anything to turn down the voltage to keep them cooler?
Old Aug 25, 2008 | 06:47 PM
Turbocivic94's Avatar
Default Re: DD with a1000 pump ?'s (zex_cool)
one word- annoying
Pump was louder than my 4" exhaust.
Old Aug 25, 2008 | 07:08 PM
Default Re: DD with a1000 pump ?'s (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">You're just too old Ruben </TD></TR></TABLE>
That's what happens when you hit 30
Old Aug 25, 2008 | 07:39 PM
.dave's Avatar
i HAS questions ?
My friend has an A1000 with the regulator on his 420A turbo Eclipse, but I have no idea about DD'ing it because its been in his parents garage the past 4 years while he's been in the Marines.
Old Aug 25, 2008 | 08:08 PM
zex_cool's Avatar
i can deal with the noise, but probably not by having to replacing the pump a few times.
how long did you have yours in ?
Old Aug 25, 2008 | 11:22 PM
V-SPEC 1's Avatar
Ran the Aeromotive voltage regulator, I'm running one on my eliminator pump and I can barely hear it when it's idling or just driving around. I have my regulator setup to go full speed at 4500rpm.
Old Aug 26, 2008 | 05:19 AM
FST GSR 1's Avatar
The A1000's are known for burning up on the street without warning. The kickdown box does help this issue. That pump is complete overkill.
The EFI Aeromotive pump flows plenty for 99% of the "street" driven imports and is a better pump for a street car anyways. I don't think many FI imports even need a A1000.
Old Aug 26, 2008 | 05:50 AM
redboost10's Avatar
Default Re: (FST GSR 1)
we have a a1000 on our s2000 sandrail, something we drive around for 45 minutes to an hour at a time and constantly running the crap out of it out on the sand. no problems yet, been about 6 months.
Old Aug 26, 2008 | 11:24 AM
zex_cool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">The A1000's are known for burning up on the street without warning. The kickdown box does help this issue. That pump is complete overkill.
The EFI Aeromotive pump flows plenty for 99% of the "street" driven imports and is a better pump for a street car anyways. I don't think many FI imports even need a A1000.</TD></TR></TABLE>
i'd probably need two of those and that may not even be enough...e85.
bump for more info.
Old Aug 26, 2008 | 11:31 AM
FST GSR 1's Avatar
If you plan to run E-85 use a pump designed to run Alcohol.
Suggestion: Magna Fuel EFI 600
Old Aug 26, 2008 | 11:52 AM
zex_cool's Avatar
who is Brett ?
i talked to Jarred @ aeromotive and he said he runs the a1000 pump on his daily driver WITHOUT the voltage controller and has had no problems. he went on to say he went across 2 states with that same car. dont know how much to belive of that but thats what he said.
and when i said how does the pump work with e85, he said, "excellent!"
Old Aug 26, 2008 | 12:17 PM
FST GSR 1's Avatar
Default Re: (zex_cool)
https://honda-tech.com/zerothread?id=2358377
For your own information.
Also, burnt up 6 Aeromotive pumps due to street use a few years ago in a friends Wild Street (WFC) car with and without a kickdown box.
I however have had no issues with my new Aeromotive EFI upmp with 2000 street/track miles, I do not run a box.
Modified by FST GSR 1 at 1:31 PM 8/26/2008
Old Aug 26, 2008 | 03:03 PM
ALL IMPORT's Avatar
Default Re: (rota92)
unless your going for over 600whp on the street that pump is way 2 much.
u only need 1000cc inj ,& a good FPR,& a single 255pump to achieve 580whp with most applications. we have done this on a few cars as well as my own with 25psi. thougth u are ar 96% dutycycle .
if u want 2 be safe jsut put another 255 pump inline & your good up to about 640whp.
Old Aug 27, 2008 | 08:44 PM
zex_cool's Avatar
Default Re: (ALL IMPORT)
its wasnt my choice at all, but i got it and im gonna use it b/c its the only thing i have.
anyone else have any other first hand experience with this pump ?
Old Aug 28, 2008 | 03:20 AM
ALL IMPORT's Avatar
i used a1000 on my car once i made more power. i put about 2000miles on it with my car on the street over 2 years time. but only drove for say 45 minutes turned the car off when i got where i was going it cooled then went again. wasn't 2 bad but did get annoying to me sometimes cause i didnt have a radio. but if your going to use it as a DD i would get the voltage controller cause u will burn it up eventually.
ahobbs
Feb 23, 2011 11:08 AM
Gokustyle
Honda S2000
95
Jul 3, 2010 05:18 PM
lemongreenhatch
Aug 7, 2006 06:12 AM
o2flow.net
Jan 11, 2006 11:48 AM
boostincoupe
Sep 10, 2003 11:51 AM
