DA 5.9 issue
Old Mar 16, 2011 | 05:42 PM
slowboy90's Avatar
Default DA 5.9 issue
i ordered some 5.9s with hubs and studs directly from dss and the hub will not fit it pushed the back bearing race out and i tried pulling them together with the axles and a big impact it wont work is there a different spindle or bearing combination its a 91 integra
Old Mar 16, 2011 | 05:56 PM
1320fuel.com's Avatar
Default Re: DA 5.9 issue
you need to put a large socket 36mm or bigger in back when your pressing it back in. if it made it in the front of the bearing thats your problem!
Old Mar 16, 2011 | 06:21 PM
slowboy90's Avatar
so what your saying is i need a smaller wheel bearing because it just slides in
Old Mar 16, 2011 | 06:22 PM
slowboy90's Avatar
but the rear bearing race appears to small do you have a part number for bearing i need
Old Mar 16, 2011 | 06:39 PM
luck4rmkc's Avatar
Why would the rear inner bearing race be smaller than the front?
That is improbable... I have worked on a lot of Honduhs and never seen that before in my life.
It sounds like you made a noob mistake when replacing the bearing and did not support the inner race from the back side when installing.
Old Mar 16, 2011 | 06:44 PM
slowboy90's Avatar
i havent replaced the bearing at this point but the factory hub slides into the rear bearing race but the dss hub wont btw when i speak of bearing race im talking the part that keeps the grease in on the back my factory hub has a place that keeps the grease in on the front
Old Mar 16, 2011 | 07:45 PM
habib's Avatar
Did you use brand new wheel bearings?
Old Mar 16, 2011 | 07:57 PM
slowboy90's Avatar
no i havent also my wheel bearing doesnt look like this http://www.google.com/imgres?imgurl=...1t:429,r:0,s:0
it looks like just a bunch of ball bearings in seats
Old Mar 16, 2011 | 08:17 PM
habib's Avatar
That is because the race isnt on top covering them
habib's Avatar
I would go get new bearings and have them pressed in with the new hubs
Old Mar 16, 2011 | 09:22 PM
reaction360's Avatar
it's pretty rare that you can remove a honda hub without the outer race being stuck to it. You've got nice new 5.9's, put new bearings in. and like someone else mentioned, support the inner race when pressing the hub into the new bearing.
Old Mar 16, 2011 | 09:42 PM
xsi-t's Avatar
they have to be pressed in. when i got my 5.9 they sent me hubs that had to be milled down they swore they were for DA but when i measured them and gave them info they asked for them back and sent me them again properly milled
Old Mar 17, 2011 | 03:29 AM
slowboy90's Avatar
any particular brand, chassis specific, or part number for the correct wheels bearings
Old Mar 17, 2011 | 03:58 AM
KleenKrew's Avatar
If im reading this correctly i think your having the same problem i just had. DSS make 2 different hubs one for stock civic spindles which requires a smaller wheel bearing. The wheel bearing has a smaller i.d. and smaller o.d. on the civic hub/spindle. If you have integra of si hubs your going to need the bigger hub that DSS makes because you wont be able to cross reference a big bearing o.d.(for the integra spindles) with a small bearing i.d(for the civic hubs) to make those hubs fit your integra spindles
Old Mar 17, 2011 | 08:19 AM
slowboy90's Avatar
so i need a different hub frank from dss told me the bearing was my problem and he gave me hubs for a da
Old Mar 17, 2011 | 10:40 AM
Garage 808 Hatch's Avatar
If you are putting DA hubs in a DA, you need DA wheel bearings. On mine, the hub was a hair too large on the last lip, so when I pressed it together the hub was binding on the spindle. but that doesnt seem to be your issue
Old Mar 17, 2011 | 12:40 PM
xsi-t's Avatar
i had the same issue brand new DA bearings brand new DA dss hubs and binding frank is the one who told me to send mine back. Once i received them from him 2nd time they worked.
Old Mar 17, 2011 | 01:17 PM
slowboy90's Avatar
So did u get oem acura bearings or aftermarket ill get with frank and see if they have revised them
Old Mar 17, 2011 | 01:37 PM
xsi-t's Avatar
Advnace auto checked part # and all frank had me take pictures and measure HUB and the were worng.
Old Mar 17, 2011 | 02:08 PM
slowboy90's Avatar
alright well im email back and forth with frank currently i asked him if the hubs needed to be milled as you said he told me to call but no one answered im awaiting a phone call i havent had time to measure my hub bore at this moment so ill see what i can come up with tonight or tomorrow i may just need new wheel bearings but i swear it looks like my bearing race for the front is made onto the factory hub
Old Mar 17, 2011 | 03:52 PM
xsi-t's Avatar
he will take care of you but he cant act like this is the 1st time. he swore up and down i was wrong then fixed it after i measured what he asked
Old Mar 17, 2011 | 07:16 PM
luck4rmkc's Avatar
The front inner bearing race is just pressed/stuck onto the hub... They always do that. Usually cutting them off is the only way to remove them, but since you have new DSS hubs and need new bearings there is really no reaon for you to mess with it.
kornerk12
Jul 29, 2008 04:51 PM
DmcL
Nov 8, 2006 09:15 AM
Bnjmn
Sep 20, 2005 03:43 PM
Surewin
Mar 2, 2005 01:26 PM
jasonb
Jun 22, 2002 07:17 AM
