cyl head
Old Oct 22, 2010 | 03:27 PM
hello1320's Avatar
Default cyl head
It's a 83mm bore block with an endyne gsr head. Do u guys have the chamber opened up to the to the bore size. Some say to do it some say don't. Just wondering what you guys think
It's a 72mm turbo setup
Old Oct 22, 2010 | 03:52 PM
West Werks's Avatar
Default Re: cyl head
Isn't the GSR a "square" chambered head...
Which means it would be a moot point...
Old Oct 22, 2010 | 04:50 PM
hello1320's Avatar
It is square but will the sides matter....there will be a over hang of 2 mm
Old Oct 22, 2010 | 06:40 PM
cibao2ner's Avatar
it should be open to deshroud valves...
Old Oct 22, 2010 | 07:38 PM
Garage 808 Hatch's Avatar
If you actually measure it is a bit bigger than 81mm. But it should be atleast opened up a bit
Old Oct 22, 2010 | 09:06 PM
hello1320's Avatar
Sounds good. That's kinda what I had in mind. Thanks guys
Old Oct 23, 2010 | 04:14 AM
tepid1's Avatar
Ask the real cylinder head gurus. Not techies....
Old Oct 23, 2010 | 01:00 PM
MrParks's Avatar
i like to deshoud to the same cyl bore, however i never had an issue not doing it either. i actually think it seals better. but who knows its all preference
Old Oct 23, 2010 | 09:19 PM
hello1320's Avatar
I have.......what would you do ?
Old Oct 24, 2010 | 12:58 PM
tepid1's Avatar
I went with what my cylinder head guy (Brad from RLZ) recommended. I had it opened up to 84mm.
It depends on what your doing with pistons and your CR as well. There is a lot to think about when making this decision. Just make sure you cover all the angles.
Old Oct 24, 2010 | 06:55 PM
hello1320's Avatar
Sounds good......Iam gonna open it up
Gillythemoon
Jun 5, 2018 10:20 AM
josh green
Jan 20, 2010 02:52 PM
ringgold
May 25, 2003 12:27 PM
fastludeh22
Aug 17, 2002 02:27 AM
