Crankcase Pressure logs
Old Nov 20, 2008 | 05:35 AM
tony1's Avatar
Default Crankcase Pressure logs
I thought this was interesting. On the hot rod and pro cars we always ran dry sump systems and I never saw one that pulled a vacuum on a high boost turbo motor, much less got down to atmospheric pressure in the crankcase. We'd usually see 1.5-5psi crankcase pressure. I setup a map sensor on the crankcase on my car to see how effective our catch can really is at big power, I think it's safe to say it's sufficient!
Old Nov 20, 2008 | 05:54 AM
JDogg's Avatar
where'd you put the map sensor?
i thought about doing this on our race car but we need to get it down the track first
Old Nov 20, 2008 | 05:59 AM
tony1's Avatar
I put it on the back of the block, where the 1/8 NPT port is from the 'black box'.
Old Nov 20, 2008 | 06:20 AM
FRernesto's Avatar
What were the end results using the T1 catch can? How much lower were the numbers in comparison to ones in theory?
Old Nov 20, 2008 | 06:24 AM
sp00led's Avatar
I must be missing a picture
DoD blocks most image hosting sites... can't see jack unless its attached via the forum.
Old Nov 20, 2008 | 06:27 AM
tony1's Avatar
Those are the results using the catch can, i won't run my car w/o a breather system to get that data. lol
That pic is hosted in the HT image gallery.
Old Nov 20, 2008 | 06:33 AM
FRernesto's Avatar
Gotch you. That is some very important data to know, so for us running 30lbs we don't see much compared to you. LOL Thanks Tony!! You rock..
josh green's Avatar
I'm not seeing a pic and we dont block anything here at work.
Old Nov 20, 2008 | 06:35 AM
twkdCD595's Avatar
x2
Old Nov 20, 2008 | 06:37 AM
tony1's Avatar
https://honda-tech.com/picture.php?a...pictureid=5741
Old Nov 20, 2008 | 06:52 AM
rota92
Guest
Posts: n/a
I've still got nothing Tony, I think they still want you to use your own server space but won't tell us lol
Old Nov 20, 2008 | 07:00 AM
alexsracing's Avatar
dosn't show the picture on the link either
Old Nov 20, 2008 | 07:01 AM
josh green's Avatar
Yeah its just a blank page.
Old Nov 20, 2008 | 07:12 AM
tony1's Avatar
How about now?
Old Nov 20, 2008 | 07:13 AM
Boner_Ben's Avatar
still nothing
Old Nov 20, 2008 | 07:15 AM
B18c1turboedEK's Avatar
I asked this question before, do you see any diffrence in your last setup too the new one? I know you are using coolant in the new one. See any diffrence?
Old Nov 20, 2008 | 07:16 AM
1992Si's Avatar
Go to the top right corner of this page and clink on the "Photo Gallery" and you'll be able to see the Data log.
Old Nov 20, 2008 | 07:17 AM
onequickcrx's Avatar
Originally Posted by tony1
How about now?
we could see it now.
Old Nov 20, 2008 | 07:19 AM
Dont you have to post a before also? How do we know theirs a diffrence?
Old Nov 20, 2008 | 07:30 AM
sp00led's Avatar
Old Nov 20, 2008 | 07:40 AM
tony1's Avatar
No difference, this can is the same as the old one, the coolant is in separate compartments, has nothing to do with the catch can.
And no, I won't do a before test. You block off all the breathers on your motor and do a test at this kind of power. lol Make sure you have a fire extinguisher ready for when it blows all the seals on the motor out and the dipstick. There IS crankcase pressure there w/o a breather, that's a known fact.
Old Nov 20, 2008 | 07:42 AM
alpha's Avatar
At 45lbs of boost through a Honda motor you're definately going to see more than 0.1lbs of pressure in the crankcase without a breather setup like that of Tony's
Old Nov 20, 2008 | 07:47 AM
twkdCD595's Avatar
Now if I could only figure out a place to put a T1 catchcan in my engine bay, damn accord.
Makes me wonder how well my setup with 2x -10an lines to a vented can are working.
Old Nov 20, 2008 | 08:10 AM
I know i was just joking around. I was just curious to knwo what the presure was before and after...hahahaha
Old Nov 20, 2008 | 08:12 AM
tricura's Avatar
That is pretty impressive...now to check mine out and see where it's at. (When I get it done)
