crank trigger for msd sci!! asap!!
Old Feb 9, 2004 | 12:43 PM
bigblu333's Avatar
Default crank trigger for msd sci!! asap!!
Hey guys, in dire need of a crank trigger for the msd sci ignition box, i an going to be running carbs with no ecu and i need the crank trigger to let the ignition know when to fire, anyone got one of these for d-series engines?? TIA
Modified by bigblu333 at 10:33 PM 2/9/2004
Modified by bigblu333 at 10:34 PM 2/9/2004
Old Feb 9, 2004 | 01:24 PM
bigblu333's Avatar
Default Re: crank trigger for msd sci!! asap!! (bigblu333)
bump, prefering someone with paypal
Old Feb 9, 2004 | 03:58 PM
bigblu333's Avatar
up
Old Feb 10, 2004 | 01:56 AM
James L.'s Avatar
Instead of the MSD Crank trigger that they offer for the 8 Cyl, which will require a need of removing two out of Four Magnet that occurs every 360 degree of Crank revolution. You can use the Honda TDC sensor to fire the Igniton box, which there is a 4 tooth trigger wheel for every 720 degree of Crank revolution, and that will be 1 tooth per firing which that is what the MSD Igntion box is looking for.(Same way of how the Fast ECU, DFI GEN 6, and 7 when picking up a Ref signal) The color of this TDC sensor is Org/Blue, and Wht/Blue and that goes for the Distributor from Year 1988 to 2003 Honda Civics. Just beware that the MSD Ignition products does not recognize the Multi-tooth Crank sensor that is on the Honda distributors, and that goes for the Fast ECU, DFI GEN 6, and 7 as well.
Old Feb 10, 2004 | 09:33 AM
indomotor's Avatar
Default Re: crank trigger for msd sci!! asap!! (James L.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James L. &raquo;</TD></TR><TR><TD CLASS="quote">Instead of the MSD Crank trigger that they offer for the 8 Cyl, which will require a need of removing two out of Four Magnet that occurs every 360 degree of Crank revolution. You can use the Honda TDC sensor to fire the Igniton box, which there is a 4 tooth trigger wheel for every 720 degree of Crank revolution, and that will be 1 tooth per firing which that is what the MSD Igntion box is looking for.(Same way of how the Fast ECU, DFI GEN 6, and 7 when picking up a Ref signal) The color of this TDC sensor is Org/Blue, and Wht/Blue and that goes for the Distributor from Year 1988 to 2003 Honda Civics. Just beware that the MSD Ignition products does not recognize the Multi-tooth Crank sensor that is on the Honda distributors, and that goes for the Fast ECU, DFI GEN 6, and 7 as well.</TD></TR></TABLE>
sinister357
Jun 5, 2005 09:02 PM
bigblu333
Feb 9, 2004 03:59 PM
bigblu333
gsracer170
Nov 17, 2003 12:47 PM
