CPR PROBLEMS
Old Jan 1, 2012 | 05:20 PM
buustedEG's Avatar
Default CPR PROBLEMS
Just wondering have anyone had issues with the CPR ...i am having issues with sync and ignition..getting TDC code instantly...any photos of wiring setup ....
Old Jan 1, 2012 | 09:28 PM
locash's Avatar
Default Re: CPR PROBLEMS
No problems here, post a pic of the wiring at the ecu, or try another distributor..?
Old Jan 2, 2012 | 03:43 AM
cpl racing's Avatar
No problems here either
Old Jan 2, 2012 | 09:04 AM
a1320addict's Avatar
Just put one on Mapps' street car...went smoothly, no complaints.
Old Jan 2, 2012 | 09:13 AM
SPOOLINmatt's Avatar
interesting to see if thats the cause. Those 3 sensors have always been quite reliable.
Old Jan 3, 2012 | 11:40 AM
ChrisMillerRacing's Avatar
We have a customer running one as well, no issues. We have another 4 kits in stock so I hope no issues pop up!!
Old Jan 3, 2012 | 11:55 AM
Garage 808 Hatch's Avatar
I was getting those codes without a CPR setup. Do you have a factory harness? or is it a custom one? are the wires for the dist signals shielded?
Old Jan 4, 2012 | 03:40 AM
buustedEG's Avatar
Yeah its shielded..stock harness some wires were temoved that was not going to be used..as far as dizzy tried 3 diff ones and two diff cab harnesses only thing not changed was eng..harnes..so maybe when my friend was removing wires tdc sensor wire was removed by mistake or ground wire maybe...put a dizzy back together and used MSD coil and car fired up on first try...still have the same codes...but runs normal so gonna try and tackle that isssue and keep u guys upsated...thanks for feed back...Thanks Mapps for the pics..looks real nice ..............anyone up close .. pics of ecu wiring would be grateful...wilg try to post some i had...
Rick777
Feb 5, 2010 12:56 PM
rebelwolf18
Oct 8, 2009 08:56 AM
extensioncordy
10
Oct 30, 2006 07:21 AM
thumbtack
Dec 8, 2004 05:11 PM
ITR981002
Apr 1, 2004 02:34 AM
