could it go 10's????
Old Dec 30, 2010 | 11:50 PM
moms_car's Avatar
Default could it go 10's????
this run is the last for 2010..setup is a LS vtec 81.5MM 12.5CR 110 octane on s300.. ALL MOTOR..this run in video was ran on a cold night..hooking up was bad..60' was 2.24...the car was tune by IMPORT EXPERTS in winder GA...the tuner there did a wonderful job..i seen a lot of turbo cars doing 10's at around 120mph.. do you guys think my car can get into the 10's if i cut down the 60'.......
http://www.youtube.com/watch?v=DiW15zA9gEU
Old Dec 31, 2010 | 12:53 AM
theidealone's Avatar
Default Re: could it go 10's????
Ive seen a buddy run 10.9 @ 124ish. I think you need a few more MPH to run 10s, but I dunno.
Old Dec 31, 2010 | 01:15 AM
cibao2ner's Avatar
how much power is that making...
Old Dec 31, 2010 | 03:50 AM
boostedcivicsir's Avatar
Mr. Badwrench
the old adege, is evert .1 off the bottom = .2 up top. but that doesnt always hold true with us.
get the 60 down and go from there. what power you making?
Old Dec 31, 2010 | 03:51 AM
Mr. Badwrench
there was probably a tenth or 2 in your shifting too.
Old Dec 31, 2010 | 07:16 AM
moms_car's Avatar
244hp @158tq something like that...i have to look for the videos..
Old Dec 31, 2010 | 07:20 AM
moms_car's Avatar
you right..its cause my trans is not to healthy..
Old Dec 31, 2010 | 07:28 AM
Humble Performance's Avatar
We ran 11.1@119 MPH with 245HP on a B20 v-tec in a 87' Prelude with a 1.6 sixty ft. It also depends on the car but I say low 11's is very doable.
Here is an 11.6 run of the car very first pass ever several years ago.
http://www.youtube.com/watch?v=yzAuu2yGuO4
We are building a new set-up over the Winter to see if we can get it in the 10's.
Good Luck with your car !
Old Dec 31, 2010 | 12:34 PM
DaBeastALLBOOST's Avatar
depends on the weight of the car take a couple hundred pouns out the window and maybe 10.9s if not i hardly doubt its hard as hell to drop .6 on a allmotor car maybe low 11s but not 10s..
Old Dec 31, 2010 | 01:03 PM
ashtons300zx's Avatar
I can see 11.2 at best with better shifting and 60ft.
An all motor SE-R went 11.6@117 with a 1.61 60ft and perfect shifts
Old Dec 31, 2010 | 04:47 PM
bauergold's Avatar
Car sounds good!
Drive the hell out of the car and it will be pretty close.
I think you will need a little more power or less weight to break 10s though.
Old Jan 1, 2011 | 08:04 AM
NY GsR's Avatar
so ur saying this 81.5mm lsv is making 244hp?
Old Jan 1, 2011 | 10:13 AM
moms_car's Avatar
it's somewhere around there.. can't remember..
Old Jan 1, 2011 | 10:26 AM
Dwreck's Avatar
what mods?
Old Jan 1, 2011 | 11:43 AM
bauergold's Avatar
How much does the car weigh?
Old Jan 1, 2011 | 01:51 PM
30psi_gst's Avatar
I dont see why the car wouldnt run 10's given the times its already run if the 11.5 in the video was with a 2.2 60ft. If the car didnt lose any MPH that is. Some say a better short time u lose MPH but most of the FWDs ive seen have gained. Mine included.
Mine N/A went 9.202 in the 8th at 79.46 with a 2.23 60ft. With slicks, nothing was changed i went 8.58 @ 81.22 with a 1.82 60ft. I also went 8.75 with a 1.95 60ft the same day as the 8.58. At some point the .1 tenth faster 60ft is .2 in the 8th saying isnt really in affect anymore IMO.
If your car runs 11.5 now. All variables aside. You should run 10's IMO with a mid 1.75-1.80 60ft if u keep your MPH. I personally feel that the way u took off in the video, u would gain MPH.
Old Jan 1, 2011 | 02:05 PM
DOHc SIdE's Avatar
Your mph is high because you weren't hooking up 11.30 at best @117ish which is still impressive @ 244whp
Old Jan 1, 2011 | 02:58 PM
moms_car's Avatar
i don't know how much the car weigh..i would think it's still in the 2's
Old Jan 1, 2011 | 03:10 PM
moms_car's Avatar
Originally Posted by Dwreck
what mods?
lsv 81.5mm 12.5cp p72 head port by Port Flow..type R trans with a 4.7 final..tune on hondata s300..ran on mh 23.0x8.0-13 slicks...
Old Jan 1, 2011 | 03:34 PM
SL0WEGG's Avatar
stock stroke? I'm thinking you can pull a 11.1-2x with a better 60'
Old Jan 1, 2011 | 06:47 PM
BADGUYNY's Avatar
What size is your shot?
Old Jan 1, 2011 | 08:29 PM
JDM JEFFREY's Avatar
Can you post a oil of the time slip
But if you can get that 60 down to a low 1.6
I can see a 11.0-10.9
Old Jan 1, 2011 | 10:01 PM
moms_car's Avatar
no shot here.. all motor..
Old Jan 1, 2011 | 10:02 PM
moms_car's Avatar
yes stock stroke..
Old Jan 2, 2011 | 04:28 PM
NY GsR's Avatar
i think someone swapped a high comp 86mm setup in ur car without you knowing...
