CLUTCH!!!!
Old Nov 27, 2009 | 11:49 AM
JLHDOHC's Avatar
Default CLUTCH!!!!
What clutch you guy's using for drag racing on your Boosted B-series setups and what flywheel. Im looking at the spec mini twin and the exedy twin. I like the pedel stiff and touchy.... What you guys recomend running Gt4088r on a sleeved 85mm gsr on 35lbs
Old Nov 27, 2009 | 12:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: CLUTCH!!!!
this issue has been covered but i will offer an answer.
psi and hp isnt really an issue.
its tq.
but if you plan on preloading and generally abusing the drive line, the twin is the way to go. twice the surface area and heat dissipation.
i dont have any exp with the spec mini twin, but installed many super twins on gt500's.
but i do have an exedy twin in my car. requires no pedal stop. i like that clutch. and had great luck with it.
Last edited by boostedcivicsir; Nov 27, 2009 at 12:18 PM. Reason: u is next to i. i cant type in the dark
Old Nov 27, 2009 | 12:16 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Originally Posted by boostedcivicsir
but i do have an exedy twin in my car. requires no pedal stop. i like that clutch. and had great lick with it.
great lick with it? Like Timex? takes a licking and keeps on ticking?
Old Nov 27, 2009 | 12:19 PM
Mr. Badwrench
hells yeah its a timex.
had to turn on the light i apparently cant type in the dark.
dustin528's Avatar
spec mini twin here and i'm loving it! I've only had it about 3 weeks, but so far so good!
Old Nov 27, 2009 | 02:39 PM
turbotypeR@SPEC's Avatar
25 Year Member
I've been using SPEC for years! LOL
Old Nov 27, 2009 | 02:47 PM
htx_jr.95eg's Avatar
yo danny pm your number bro...
Old Nov 27, 2009 | 03:41 PM
ExospeedAMcrx's Avatar
Get the Tilton Carbon/Carbon Clutch.
Old Nov 27, 2009 | 07:24 PM
JLHDOHC's Avatar
looking into either the tilton or the spec...... thanks guys!
Old Nov 27, 2009 | 07:25 PM
Blueberry1320's Avatar
Exedy twin 
Old Nov 27, 2009 | 08:10 PM
sweetfwdthunder's Avatar
I use the spec twin and i love it!
Old Nov 28, 2009 | 09:42 PM
runsfromdacops's Avatar
i love my comp twin,
Old Dec 5, 2009 | 02:05 PM
jordaninu's Avatar
comp twin disk is the way to go no doubt
Old Dec 5, 2009 | 10:33 PM
speedbynumbers's Avatar
comp clutches are inexpensive way to go but they recommend a pedal stop exedy, spec or even clutch master twin disc are three I would pick from
Old Dec 6, 2009 | 07:23 AM
SIXTY-1HATCH's Avatar
Rockin the exedy here! You sound like your running almost the same setup as me. I have been beating on my exedy twin for almost 2 years now. Joy riding on the streets, driving it to the track, running high 10's, and driving it home and it's still going strong. I'm runnin a darton 84mm gsr. Was on a t3 60-1, but just installed a new mani and gt4088r. Thing should be BADASS!!!
EXEDY FTW, don't need a bump stop!!
Old Dec 7, 2009 | 12:14 AM
cfwthb_94's Avatar
I'm not familiar with what you guys are referring to when you say bump stop when using certain clutches
Old Dec 7, 2009 | 10:51 AM
JLHDOHC's Avatar
how you liking that gt4088r what ar are you using I have the full-race manifold with twinn 44mm wastegates the thing spools my turbo like no other lol I am running a 1.06ar it is badass you will love it
Old Dec 7, 2009 | 11:25 AM
theyre talking about pedal stop. Prevents over engaging on certain clutches by limiting the pedal from how much its depressed.
Old Dec 7, 2009 | 12:37 PM
powerneedy's Avatar
so who has the best prices on spec?
Old Dec 7, 2009 | 01:29 PM
jdm inc's Avatar
Originally Posted by Blueberry1320
Exedy twin
x2
Old Dec 7, 2009 | 07:33 PM
cfwthb_94's Avatar
I guess I don't know how you would "over engage" a clutch. I'm having problems with my comp clutch stage 5 sprung, and wondering if this might be the problem I'm having with it. At high rpm, full load on a turbo car, it acts like it doesn't want to engage and having problems going into gear. On a side note, could it be a flywheel problem?
Old Dec 8, 2009 | 02:21 AM
25 Year Member
pm me for pricing
Old Dec 8, 2009 | 02:55 AM
tepid1's Avatar
Over engaging the clutch will cause excessive wear on the clutch pressure plate and on the thrust bearing in the motor if not done properly.
Old Dec 8, 2009 | 11:59 AM
drocto3000's Avatar
i had the same problem w/competition clutches i tried 2 different 6 puck sprung clutches of theirs and both wouldnt go into gear at high rpm(full throttle shift), i changed to act 4 puck unsprung and no problems. this was on a budget b20vtec. you know choung, talk to him hes had a few customers with the same promlem.
Old Dec 8, 2009 | 12:01 PM
cfwthb_94's Avatar
I was one of the ones that brought this problem to his attention. My clutch is a stage five 4 puck, and was perfect in my car. I transfered it over to a friends car and it's been nothing but problems in that car. Just wondering if this clutch stop would help alleviate the problem. Also what would be the difference from his car to mine.
