Clueless...help me out please!
Old Jun 16, 2004 | 09:38 PM
DOHCarp's Avatar
Default Clueless...help me out please!
Alright so I have an engine that runs great until 5500 RPM's.
It is breaking up and loosing power after 5500. At first I thougt it was ignition related, but a brand new distributor, plugs, and wires did nothing. I then started thinking it was compression related so I did a compression check 240, 240, 240, 240. Now I am stumped, but I decided to give it a leakedown test since I just got a new tester. The leakdown test showed 15%, 15%, 100%, 45%. I figured they were going to be a little high since it is a brand new engine and maybe has 20 miles on it. now in #3 and 4 I can't tell where the leak is coming from, but why wouldn't a 100% leakage show up in a compression test, and why does the car run great under 6000 rpm's.
So I pulled the motor apart thinking I F@#$ up two pistons, but I was wrong they both look perfect and not a scratch on any of the walls. So I go to the head and check every valve to see if they were bent , but every one was perfect. I had the head pressure checked and it turned out perfect. I then put a strait edge on the block and it was perfect stepped deck was consistent all around.
What can I be overlooking. On the dyno it showed 250hp on 8psi right before it starts to break up and loose power. WHAT COULD I BE MISSING!
her are some FAQ about the motor.
RS machine sleeved block
B18B1
B16A2 head supertech valve-train
JE pistons and eagle rods
ARP head-studs
Also there was no oil in my coolant and no water in my oil. Car did not overheat and ran like a champ on the street. Anybody have any ideas.
Sorry I put this in two forums but i figure alot of the people in the drag forum have experiance with built motors.
Old Jun 16, 2004 | 09:42 PM
Rtype16's Avatar
Default Re: Clueless...help me out please! (DOHCarp)
What engine management are you running? What size injectors do you have? Are they low or high impedence if they are low are you running a resistor box?
Old Jun 16, 2004 | 09:45 PM
DOHCarp's Avatar
Default Re: Clueless...help me out please! (Rtype16)
im running hondata s200 with MSD 96lb injectors with resistor box. also the air fuel was 11.8 straight across.
Old Jun 17, 2004 | 08:03 AM
Rtype16's Avatar
What is the gap on your spark plugs and what kind are you using?
Old Jun 17, 2004 | 08:23 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">What is the gap on your spark plugs and what kind are you using?</TD></TR></TABLE>
i was going to ask the same thing, i had a similiar problem last year, andthis was the culprit..
DOHCarp's Avatar
I have tried NGK heat range 8's and 7's with .025 gap and ZEX cold plugs....can't gap them.
Old Jun 17, 2004 | 09:05 AM
Rtype16's Avatar
whoops i din't actually look at the leakdown numbers. A compression check is good, but a leak down is another good way to find out if a motor is messed up. Can you tell if it is coming from the exhaust, intake, bubbles in the radiator or from the valve cover.
Old Jun 17, 2004 | 10:34 AM
chrisCNL's Avatar
Old Jun 17, 2004 | 04:20 PM
DOHCarp's Avatar
well i just put it back together...everything was to spec so wish me luck.
94eg!
Jan 1, 2017 11:16 PM
zCivic
Apr 28, 2007 01:17 PM
DOHCarp
Jun 17, 2004 10:09 AM
joeg26er
Feb 1, 2002 08:42 PM
