chute help...
Old Oct 16, 2011 | 06:33 AM
061000rr's Avatar
Default chute help...
Ok got a used chute for the car to be able to make Wcf. The loop on the spring launcher is broke. Is it junk or can I use a heavy duty piece of string? I can't load a pic off my phone for some reason. But is the Simpson chute with the spring pilot chute? Its has the loop that you thread through the chute bag holes to keep it shut. I guess I'm asking how much pressure is on this piece of string?
Old Oct 16, 2011 | 06:40 AM
tepid1's Avatar
Default Re: chute help...
Not much pressure when all of the flaps are wrapped around the chute. Heavy string should do the trick.
Old Oct 16, 2011 | 07:28 AM
061000rr's Avatar
Cool. Thanks man
Old Oct 16, 2011 | 08:18 AM
061000rr's Avatar
One more ? You can cut the chute release cable right? Just pull the inner wire thru then cut the cable then trim the little wire to the lenght you want?
Old Oct 16, 2011 | 08:41 AM
dturbocivic's Avatar
i agree with tepid, a heavy string should work.
yes you can cut the inner cable. i highly recomend doing this, so it "lessens" the amount you need to push/pull the chute release lever.
new_climber
15
Nov 9, 2009 10:51 PM
DaveF
Jan 19, 2007 09:57 PM
tchen415
Sep 26, 2006 07:23 PM
JLefevers
Apr 8, 2006 06:21 PM
LudeJdm
14
Jul 12, 2005 04:56 PM
