cam trigger and @300
Old Sep 7, 2011 | 01:01 PM
  #26
xenocron's Avatar
Default Re: cam trigger and @300
There is also an AEM Class and a MOTEC class going on in less than two weeks in NJ.
So if you decide to stick with the AEM, you should come up to that class and learn some more.
If you decide to go Tony's route and get the MOTEC, you can come to the MOTEC class and learn about that instead
http://efi101.com/schedule.php?cat=EFI&country=USA
Look at that class schedule for more info and pricing.
Old Sep 7, 2011 | 01:49 PM
  #27
061000rr's Avatar
the class says aem motec combo. does 895 include both classes or is it cheaper for just one class?
Old Sep 7, 2011 | 02:54 PM
  #28
xenocron's Avatar
Check each class individually
AEM - $345 alone (sept 17)
Motec -$595 alone (sept 18)
Or the combo (both classes) like you noted
Old Sep 23, 2011 | 07:07 AM
  #29
061000rr's Avatar
quick ? can you run 1 aem v1 on 2 cars with cam triggers and cop without having to re sync the ignition every time you change it from one car to the next?
Old Sep 23, 2011 | 09:03 AM
  #30
B18c1turboedEK's Avatar
Nope you have to always sync it.If you save the maps and load them each time you switch you would be fine also. So you only have to do 1 time
Old Sep 23, 2011 | 09:13 AM
  #31
DDTECH's Avatar
FAST DTA or ProEFI.
Old Sep 23, 2011 | 09:43 AM
  #32
cibao2ner's Avatar
the motec m84 isnt a bad deal...but the aem is like 1100 and you can get a full race harness for around 2200 thats 3300...and you can use all of aem features...
but the motec is 2800 and then after a full race harness your talking about 5k....
for someone who has this sport as a hobby not a job...spending 5k on the engine management is alot of money...
right now my goal is 950whp on my turbo build but dont want a cheap engine management..so far aem v2 is the number 1 choice but motec m84 is also been considered...what i like about the motec is that you can even run it under water and you can use it on any 4 cylinder not just a honda...
Old Sep 23, 2011 | 09:47 AM
  #33
TempestRacing's Avatar
thats the nice part about a m800. it will work on ANY car you ever own
-Joe
Old Sep 23, 2011 | 09:52 AM
  #34
cibao2ner's Avatar
m84 is expensive but if u ever buy another 4 cylinder ie evo,s2000,scion frs,sti, all u need is and adapter harness and u can run it with the same ecu...
btw joe how big of an intercooler can u run on a jdm front? i remenber the jdm teg from tempest back in the day...im gonna run jdm front on mines and dont want a 3 piece front..
Old Sep 23, 2011 | 01:05 PM
  #35
061000rr's Avatar
here is why im asking, tony mentioned just buying 1 m48 and running it in both my street car and my race car. well a m48 isnt going to happen for a while. so i bought 2 T1 triggers and im going with k series coils on both cars witch are both turbo sleeved b16. almost identical setups. so if i tune both cars on 1 aem and save both tunes on my laptop it will save the sync settings of both triggers and both tunes without having to do anything but plug it in and load the map per what car im driving?
Old Sep 23, 2011 | 02:25 PM
  #36
Yes sir...
Old Sep 24, 2011 | 06:45 AM
  #37
my integra had a 24x12x3.5 on it. you have to modify pretty much everything to make it fit, but it will work
Old Sep 24, 2011 | 08:12 AM
  #38
061000rr's Avatar
Originally Posted by B18c1turboedEK
Yes sir...
thank you sir. thats what i wanted to here!
Old Sep 24, 2011 | 06:33 PM
  #39
cibao2ner's Avatar
i have a similar one 24x11.75x3.5 was hoping to make around 950whp with it if not get a 4.5 inch core and make a custom one......but thanks for the info..
ludeking1007
Engine Management and Tuning
10
Aug 16, 2009 12:16 AM
quik sol
Nov 12, 2006 07:40 PM
allmotorls95
Mar 12, 2003 06:31 PM
