Cage Question
Old Mar 8, 2008 | 04:28 AM
Topdawgg's Avatar
Default Cage Question
2 Piece Main hoop, is it legal? Welded at the top
OR does it all have to be one piece.
We are designing a cage and trying to make it as safe and legal as possible..
Any tips or pointers would be great
Old Mar 8, 2008 | 05:48 AM
T4 Neon's Avatar
Default Re: Cage Question (rota92)
I think butt-welding the tubes is out of the question, but there is information in the handbook about slipping a larger piece over the joint and welding both ends. Contact your local NHRA tech official and ask him / her.
Old Mar 8, 2008 | 06:21 AM
Evile140's Avatar
Default Re: Cage Question (T4 Neon)
I did this for my front down bars form the main hoop to the floor. To get them as tight s I wanted I couldn't get them in as one piece. I took another piece of moly tube, ripped it down one side enough where I could squeeze it to a smaller diameter. Slipped each end into the normal size bar and welded the middle up. Pulled the ends free and finish welding it.
I sued this piece as an internal coupling along with a weld that connected all the pieces. I also put 4 rosette welds. But I am only shooting for mid 10's. I have not had it looked at by a tech yet. But I have no fear of the joint.
Old Mar 27, 2008 | 11:41 AM
Topdawgg's Avatar
this is what we did, and I have no worries that it is not strong enough... Im just wondering if It wouldnt pass tech If i did this.
put a 2 foot length of pipe inside the larger diameter pipe and welded it in place..
Old Mar 27, 2008 | 04:21 PM
White .:R32's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">put a 2 foot length of pipe inside the larger diameter pipe and welded it in place..</TD></TR></TABLE>
And that is called a sleeve
Old Mar 27, 2008 | 05:45 PM
Topdawgg's Avatar
and sleeves are perfectly legal?
Old Mar 28, 2008 | 03:53 PM
k24killer's Avatar
ryan, why didnt u bend it all in one piece??
Old Mar 28, 2008 | 11:41 PM
therealpoorboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">and sleeves are perfectly legal?</TD></TR></TABLE>
you must have at least 6 inches inside of each of the pieces you are joining. then you need a 3/8 or so hole 6 inches away from the joint to show that the inner sleeve goes that far. and they want the holes every 90 deg at the six inches then weld the bar to the sleeve in those spots.
i welded 3 holes and left the 4th unwelded to prove the sleeve went that far and the car was certified like that.
Old Mar 29, 2008 | 06:45 AM
Topdawgg's Avatar
well I have more then 6 inches on each side..
siblues
Welding / Fabrication
24
Jan 13, 2011 05:48 PM
Slowp0ke
Nov 4, 2010 01:20 PM
SPOOLINmatt
May 16, 2006 12:55 PM
