burnout problem
Old Jul 12, 2009 | 04:16 PM
Gkdc182's Avatar
Default burnout problem
I have 92 civic hatch with 24.5.9.13 slicks....the car made around 660 on race and 400 something on pump gas. I just went to the track yesterday and when i went to do a burnout it will start to go until it bounces off the rev limiter more than twice it just stops. So i get to the line and go and the car will fly down the track but no burnout means no grip. Any idea what is going on!? i tried both gears for burnouts first then second!
Old Jul 12, 2009 | 04:44 PM
CETVTOGEM's Avatar
Default Re: burnout problem
your using the e-brake right? and never do 1st gear burnouts, not enough speed to light up the tires enough, stick with 2nd gear.
Old Jul 12, 2009 | 05:35 PM
Gkdc182's Avatar
yes e-brake...changed plugs before i ran... just bogs as soon as it hits the rev limiter after two or three times, just falls on its face
Old Jul 12, 2009 | 05:45 PM
slowboost93's Avatar
i have a friend with a 9sec civic and i was talking to him and he has his in 3rd gear and pegs antilag\stutter box and has the e-brake on and does his so hopefully that helps man
Old Jul 12, 2009 | 05:50 PM
jdm inc's Avatar
wats ur antilag seton?
Old Jul 12, 2009 | 06:04 PM
SPOOLINmatt's Avatar
2nd gear works best, I've had to do first gear burnouts for several months due to issues with 2nd gear and i still was cutting 1.6 60 foots.
Old Jul 12, 2009 | 09:44 PM
dustin528's Avatar
mine will hit boost cut during the burnout after on the rev limiter for a little bit. I do second gear burnouts... It will run 14.5-15 psi down the track but during the burnout sometimes it will hit boost cut which is set at 16 psi. I need to turn it up.
That could be it. does it backfire like when it hits boost cut, or spark is cut??
Old Jul 13, 2009 | 09:02 AM
Tommy T's Avatar
3rd gear burnout FTW!!!
Old Jul 13, 2009 | 09:59 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
it sounds like the fuel enrichment on your revlimiter might be a little excessive.. maybe it's excessive and the car is cuttin spark which is causing all the fuel to coat your plugs and make it run like poo poo after you hit rev limiter.. talk to your tuner and see if he can make any adjustments..
also, what did you use to tune?
Old Jul 13, 2009 | 01:56 PM
Gkdc182's Avatar
im using hondata s300
Old Jul 14, 2009 | 09:51 AM
hello1320's Avatar
Do it in third. The wheel speed will be so fast that u will only need like a 2 second burnout. Doesnt matter if i carry the burnout past the tree...or do a 5 footer the car hooks the same. Try to stop a little past the water.and the the boost come up on the 2 step before u let the clutch go.
Old Jul 14, 2009 | 05:18 PM
418whpturboD's Avatar
1st gear burn outs work just fine.. i have talked to people with 9 second hondas, and they do 1st gear burnouts and are cutting 1.5-1.6 60 foots.. i guess it is up to you on what gear youd like to do the burn out in.. but i dont know about you but i like keeping my tranny in my car and not pulling it out to repair it cuz i messed it up cuz of a burnout..
Old Jul 14, 2009 | 05:22 PM
hello1320's Avatar
9.89@150
Old Jul 14, 2009 | 07:11 PM
Gkdc182's Avatar
yeah i just dont understand why it falls on its face even when i go in first on the street and it goes on the limiter. but i will try second and third gear burnouts to see what happens...thanks for all the posts
Old Jul 14, 2009 | 08:50 PM
KevinMBracing's Avatar
Do it in 3rd gear and try to keep the throttle steady and stay off the revlimiter as much as possible.(It will be easier to control your revs,since your doing it in 3rd gear.Then let the car pull you out the water.
Old Jul 15, 2009 | 04:30 PM
Honda Bull's Avatar
Dropping the clutch for 3rd gear isn't much different than dropping it in 1st IF you have the power to do it. The clutch will get more abuse than the gearset. If you don't have the power and you end up bogging, that's a different story.
I agree with your main point though about 1st gear burnouts. A lot depends on the tire though, too.
Old Jul 15, 2009 | 07:01 PM
Gkdc182's Avatar
thank you for all the help and i will be trying 2nd and 3rd gear burnouts this friday coming up. I will post up what happens..Thanks again
Old Jul 16, 2009 | 08:21 AM
d16z6Tcrx's Avatar
what about 3rd gear burnouts on stock axles? preload on a burnout too?
Old Jul 16, 2009 | 05:02 PM
Lo-Buck EF's Avatar
yes, preload on a burn out too.
dr.vroom
Transmission & Drivetrain
11
Apr 30, 2014 11:31 AM
ekcoupe88
Honda Civic (2006 - 2015)
16
Apr 26, 2007 09:05 AM
jdm_DC2R
Mar 21, 2006 08:37 AM
paawk2000
May 23, 2005 11:46 PM
oddcivic
Feb 6, 2002 12:18 PM
