burning out
Old Oct 7, 2004 | 06:49 PM
red_crx's Avatar
Default burning out
I recently tried to do a 2nd gear burnout, but nothing happened. I've done 1st gear burnouts, so i know my tires will smoke.
This is what i did: 1. Pulled the e-brake up
2.I revved up to 45k and then 5k rpm
3. dropped the clutch and nothing
Can someone help me out with this one? Plus it on a b16 crx if that helps any.
Old Oct 7, 2004 | 07:11 PM
Group Tenacity's Avatar
Default Re: burning out (red_crx)
Not enough power to start the burn out in second gear IMO... i could be wrong tho..
Mike...
Old Oct 7, 2004 | 08:25 PM
ms1motorsports's Avatar
Not enough power for the slicks you have. Just do 1st gear burnouts.
Old Oct 7, 2004 | 09:50 PM
james111's Avatar
drag radials or slicks?
if radials, then have about 12-14psi in them
as u come thru the box slightly tap the throttle to cover the tire w/water
only pull thru the box about 1foot or so
set ebrake
bring rpm up to 5-6k and slip clutch to full
bring rpm up and to from 5-7k while turning wheel left and right
when u feel the car starting to creep forward let go of the ebrake and give her one
last rip forward not too hard but enough to drag the sticky tire forward out of the
water if any is still there......
wih this method i was ablr to pull 1.71 60ft with bfg drag 225 65 15 at 12psi
also wih drag radials the less the tread the better......
hope this helps
regards
james
Old Oct 7, 2004 | 10:31 PM
JL's Avatar
JL
1st gen b16? is it stock?
Old Oct 7, 2004 | 11:13 PM
MAD SOHC's Avatar
Default Re: burning out (james111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james111 &raquo;</TD></TR><TR><TD CLASS="quote">drag radials or slicks?
set ebrake
hope this helps
regards
james</TD></TR></TABLE>
crowder13
Oct 30, 2007 03:45 PM
integralactic
Jun 22, 2006 05:45 AM
sa90eg
Mar 17, 2006 08:53 PM
red_crx
16
Oct 8, 2004 10:57 AM
18G_prelude
Mar 26, 2004 05:31 PM
