burn out
Old Feb 16, 2003 | 01:08 PM
TypeR 599's Avatar
Default burn out
how do i do a 4-5 second burnout without bouncing off the rev limiter? i'm going to be using drag radials next time i go to california speedway. do i do it in second gear? what 60' would i expect with a set of brand new drag radials(nitto 555r 205/50/15)? i'm hoping 1.9? my best was a 2.4 and pulled off a 14.7@97. i'm aiming for low 14's with these tires.
Old Feb 16, 2003 | 03:10 PM
4piston's Avatar
Default Re: burn out (TypeR 599)
Second gear and just modulate the throttle. Don't slip the clutch.
Why do you want a 4-5 second burnout? You can heat them up just as good in half the time. I do short ones.
Old Feb 17, 2003 | 01:41 AM
b18b-HB's Avatar
Default Re: burn out (4piston)
Old Feb 17, 2003 | 01:00 PM
TypeR 599's Avatar
so i get my wheels into the water and rev in second and dump the clutch? i have no clue how long it takes to get the tires warm..
Old Feb 17, 2003 | 06:10 PM
jlicrx's Avatar
don't do the burn out in the water - just drive through water and stop as soon as you clear the water, then pull the e-brake - you will have enough water on the tires to get them spinning and heat them up - if you stay in the water, you will just cool them down when you get out of the throttle and end up with water on the tires which doesn't make for a very good launch.
i would do it in 1st gear - easier on clutch
[Modified by jlicrx, 8:11 PM 2/17/2003]
Old Feb 17, 2003 | 08:36 PM
bretx0r's Avatar
put it in 2nd rev it up drop it once u get em spinning just get off the throttle when u get close to the redline.
and yeah, spin em a little in the water so ur tire gets a little water on the surface. dont burn out IN the pit itself
once u feel youve burned out enough let the ebrake go and let the car move forward and get off the throttle and youll feel them grab.
then stage
at least thats what i do.
[Modified by bretx0r, 5:38 AM 2/18/2003]
[Modified by bretx0r, 5:39 AM 2/18/2003]
Old Feb 19, 2003 | 03:09 PM
TypeR 599's Avatar
Default Re: burn out (bretx0r)
ok thanks guys
i'll try it in second since i need a reason to get a new clutch anyways.
[Modified by TypeR 599, 4:10 PM 2/19/2003]
The_Godfather
Dec 24, 2012 04:47 AM
Rooftop voter
Jul 21, 2009 07:50 PM
black sohc civic
Apr 8, 2004 11:22 PM
18G_prelude
Mar 26, 2004 05:31 PM
austrian type-R
Aug 20, 2002 06:27 PM
