Build ????
Old Feb 22, 2010 | 04:56 AM
hawkturbo's Avatar
Default Build ????
Hello HT sorry for my noob ??? and my inglish like always lol
ok need to now if y put the acl race bearing need to balance the crank o just micropolish is a ls/vtec to make 500 HP whit turbonetics 62-1 or what you think acl standart bearings
espanol
hola quiero saber si para poner los bearing acl race tengo que balancear el ciguenal o solo tengo que haser lo de micropolish no pongo los bearing oem por que como soy yo mismo que harmare el motor creo que me coviene mas con los acl por que solo es ponerlo y dicen que son buenos para los caballos que busco mi carro no es de uso diario solo para la pista quiero conseguir unos 500 WHP en un ls/vtec con una turbonetics 62-1
Thanks
Gracias
Old Feb 22, 2010 | 04:14 PM
140sx's Avatar
Default Re: Build ????
just polish it. race bearings or standard acls. no need to balance it
Old Feb 22, 2010 | 06:09 PM
hawkturbo's Avatar
Thanks. And for those bearing no need to now the clerance right
Old Feb 24, 2010 | 03:26 AM
hawkturbo's Avatar
More coments ??????
Old Feb 25, 2010 | 10:37 PM
140sx's Avatar
no you dont have to, just throw them in there and go
Old Feb 25, 2010 | 11:11 PM
ralph11sec's Avatar
no!
you have to fit them properly.
acl bearings or even the OEM colored bearings are not plug and play.
you have to fit them through polishing to get desired clearance. some fancy builders use precision equipment, like digital micrometer or something, while others like me just use plastigauge.
if it's on a tight side, then, break them in properly.
use proper lubrication also.
IN FILIPINO.
hindi! kelangan mo mag fitting ng rod/main bearings. hindi salpak lang yan. intendies?
Old Feb 26, 2010 | 10:55 AM
hawkturbo's Avatar
thanks for the advice
xotic_crx
Oct 23, 2015 07:00 AM
blakh
11
Dec 20, 2007 02:16 PM
IN VTEC
Mar 18, 2006 08:40 PM
