broken CV joint
Old Jun 5, 2008 | 02:43 PM
Jarfal's Avatar
Default broken CV joint
my turbo 94 delsol keeps breaking cv joints always.
is there any way to make its life longer?? SEARCHING FOR CUSTOM IDEAS
forgot to mention that the diff is welded
NEED IDEAS ASAP.
cheers
Old Jun 5, 2008 | 02:57 PM
Innes's Avatar
Default Re: broken CV joint (Jarfal)
there are great aftermarket options on the market nowadays
you are running oem axles currently?
check out http://www.driveshaftshop.com -- they have good options, reasonably priced.
Old Jun 5, 2008 | 03:01 PM
Jarfal's Avatar
Default Re: broken CV joint (Innes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innes &raquo;</TD></TR><TR><TD CLASS="quote">you are running oem axles currently?</TD></TR></TABLE>
Yes
Tanks alot
Old Jun 5, 2008 | 10:59 PM
civickiller's Avatar
preload
Old Jun 6, 2008 | 12:35 AM
Jarfal's Avatar
Default Re: broken CV joint (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">preload</TD></TR></TABLE>
what do you mean?
Old Jun 6, 2008 | 03:56 AM
1992Si's Avatar
Someone needs to make a sticky about preloading.
OP is your car lowered? The axles were designed for OEM style ride height's.
Preloading; push in clutch, put tranny in 1st gear, pull up hand brake, keeping thumb on button, let clutch out until you feel it begin to grab, while keeping rpm's up and pushing your anti-lag button. When the last yellow light comes on, lower the hand brake, let the clutch out, let off the button, keep the rpm's up, all at the same time.
BTW if you see the green light, you loose.
Hint; duct tape the hand brake button in.
Got it ?
Old Jun 6, 2008 | 05:35 PM
patrick4588's Avatar
Default Re: (1992Si)
[QUOTE=1992Si].
QUOTE]
lmao. i have made a pass before with the hand brake on the first or second click; didnt drop down all the way.
Old Jun 6, 2008 | 06:11 PM
BlakeJ53's Avatar
Default Re: (patrick4588)
good preload info
Old Jun 7, 2008 | 12:54 AM
Jarfal's Avatar
Default Re: (BlakeJ53)
Im using this method <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">preload</TD></TR></TABLE>
the problem is in the burn-out now ...
GOOD INFO
Old Jun 7, 2008 | 03:14 AM
1992Si's Avatar
Default Re: (Jarfal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jarfal &raquo;</TD></TR><TR><TD CLASS="quote">
GOOD INFO</TD></TR></TABLE>
Check alignment of your suspension parts, Is your car lowered a lot ? The CV joints need to be some what level during the rapid spinning. Think about the angles your creating.
Old Jun 8, 2008 | 04:33 AM
jDMJeRk's Avatar
2nd gear, as soon as you see smoke, your good. Anything more then that your wasting rubber
Old Jun 8, 2008 | 04:42 AM
Jarfal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">
Check alignment of your suspension parts, Is your car lowered a lot ? The CV joints need to be some what level during the rapid spinning. Think about the angles your creating.</TD></TR></TABLE>
yes its lowered but not lower than 4' inches, better i check the alignment issue..
Thanx
Old Jun 8, 2008 | 04:47 AM
Jarfal's Avatar
Default Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">
2nd gear, as soon as you see smoke, your good. Anything more then that your wasting rubber </TD></TR></TABLE>
burning in the 2nd continue about 2meters to the front, makes good grip i beleive.....
Old Jun 8, 2008 | 06:13 AM
1992Si's Avatar
Thanx </TD></TR></TABLE>
IMO almost 4inches is a lot when your talking about this.
By alignment issues I meant the 4" drop. raise the car to more like a 1-2"drop IMO.
Old Jun 8, 2008 | 11:10 AM
Jarfal's Avatar
but if I raise it, is it going to effect aero-dynamics??
Old Jun 8, 2008 | 04:08 PM
1992Si's Avatar
At the speeds your traveling, not really. You may want to raise the rear a bit too.
It's more important to stop breaking axles.
Old Jun 8, 2008 | 04:52 PM
TimKennard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=1992Si].
QUOTE]
lmao. i have made a pass before with the hand brake on the first or second click; didnt drop down all the way. </TD></TR></TABLE>
i took a die grinder to the teeth that hold the ebrake. i pulled the ebrake until it was really tight, then went two teeth below that and ground the rest smooth. works really well. this way i can use it to hold the car on the trailer and it won't get in the way when staging.
Old Jun 8, 2008 | 10:04 PM
jDMJeRk's Avatar
burning in the 2nd continue about 2meters to the front, makes good grip i beleive..... </TD></TR></TABLE>
Yeah drive through it.... I thought that was self explanatory
spoonracer84eg
13
Oct 28, 2006 11:58 AM
importdude2000
Oct 3, 2004 01:48 PM
Kyles ej1
11
Sep 4, 2004 09:01 AM
bo0sted
Jan 1, 2004 05:24 PM
austrian type-R
Apr 30, 2003 05:29 AM
