broken axles :(
Old Mar 31, 2007 | 06:24 PM
Chiovnidca's Avatar
Default broken axles :(
Ever see both axles break? I pulled it off somehow, by the 1/8 mile it was coasting. Didn't think it was possible without a spool.
Old Mar 31, 2007 | 07:06 PM
1FSTHATCH's Avatar
Its still possible, even though you didnt have a spool..Once the first axel broke all the power shifts to the other axel..Atleast you and the car are ok!!
Old Mar 31, 2007 | 09:45 PM
darrinbrewer's Avatar
Default Re: (1FSTHATCH)
i see green boots! those gators?
i seen the title, and just guessed they were gators.
i hear 9 out of 10 people's stories with gators breakin...my freinds 450hp sfwd crx sheared his off where the splines go into the hub; on his 1st run of the day, ran OEM HONDA all day the rest of the day..no prob's
Old Mar 31, 2007 | 11:13 PM
RaceProfessor's Avatar
Default Re: (darrinbrewer)
Gators looks as they are oem reman's with green paint.
Old Apr 1, 2007 | 05:27 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Its still possible, even though you didnt have a spool..Once the first axel broke all the power shifts to the other axel..Atleast you and the car are ok!!</TD></TR></TABLE>
The car tried to do an instant lane change when they snapped. I was pretty violent.
They're fidanza axles, got em from jegs a couple years ago when they had em on sale. Rated for 300hp, i've got about 4000 hard miles on em at 400+.
Old Apr 1, 2007 | 05:30 AM
sc4dr's Avatar
Default Re: (Chiovnidca)
Whats crazy is that you managed a 12.5 out of that run!
Old Apr 1, 2007 | 07:40 AM
1 2 NV's Avatar
Default Re: broken axles :( (Chiovnidca)
i broke both axles at the line once. gators with a spool. ALL MOTOR
GATORS=OEM with green paint for sure.
Old Apr 1, 2007 | 08:17 AM
Default Re: broken axles :( (1 2 NV)
fidanza makes a better axle now, a freind bought a set, and the next week the shop said fidanza called and wanted the old set he just sold back, that they would send out the new improved set..about last october maybe...
a freind of mine said he went to titan, and next door was a set of rental storage buildings...one had a guy inside painting oem axles green, with a big gator logo banner hanging in the back
Old Apr 1, 2007 | 09:30 AM
Chiovnidca's Avatar
Default Re: broken axles :( (darrinbrewer)
I think i'll go with the dss 2.9 axles.
Old Apr 1, 2007 | 10:40 AM
sc4dr's Avatar
Or rebuilt $65 ones that might last all season
Old Apr 1, 2007 | 02:27 PM
tmac007's Avatar
Default Re: broken axles :( (sc4dr)
I had the same thing with DSS stage 3's. More my fault though lol. Now on Axle Systems stage 5's with no problems
Old Apr 2, 2007 | 06:04 AM
Jason703Racing's Avatar
Default Re: broken axles :( (tmac007)
were those drive shaft shop stage 3s?
Old Apr 2, 2007 | 03:44 PM
Chiovnidca's Avatar
Figured it would be a good idea to check the clutch while the transmission is out of the car. I'm totally confused:
Old Apr 2, 2007 | 03:48 PM
cluelessmale's Avatar
wow I guess you are good a breaking stuff
Old Apr 2, 2007 | 04:15 PM
Chiovnidca's Avatar
Default Re: (cluelessmale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale &raquo;</TD></TR><TR><TD CLASS="quote">wow I guess you are good a breaking stuff</TD></TR></TABLE>
Seems that way doesn't it? I was doing ok till i started running the 24.5x8.5 slicks.
Old Apr 3, 2007 | 12:02 AM
Lamchop0000's Avatar
crazy
Old Apr 3, 2007 | 09:58 AM
AznPimpS's Avatar
Default Re: (Lamchop0000)
when things go bad, they go bad!
Old Apr 3, 2007 | 10:03 AM
g2turbo's Avatar
Default Re: (AznPimpS)
Hey maybe I can borrow your slicks while your car is down and keep them warmed up for you
j/k sent you a PM
What clutch setup is that? How did the disc looK?
Old Apr 3, 2007 | 01:52 PM
94whtgsr's Avatar
damnnn... .it looks like heat might have had something to do with that..
Old Apr 4, 2007 | 03:12 AM
Chiovnidca's Avatar
Default Re: (94whtgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">
What clutch setup is that? How did the disc looK?</TD></TR></TABLE>
Clutchnet 3x
Disk doesn't look to bad compared to the plate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94whtgsr &raquo;</TD></TR><TR><TD CLASS="quote">damnnn... .it looks like heat might have had something to do with that..</TD></TR></TABLE>
Cant remember the last time I adjusted the clutch cable. That's probably why it was slipping.
BoltonGSR
Apr 20, 2009 01:49 PM
gacraig
16
Oct 26, 2006 05:56 PM
Relick!
Jan 21, 2004 12:48 PM
RacerSi
Nov 7, 2003 01:51 PM
austrian type-R
Apr 30, 2003 05:29 AM
