is the brake prop valve needed?
Old Oct 24, 2008 | 07:26 AM
MrBui's Avatar
Default is the brake prop valve needed?
is it necessary to have one in a car? reason i ask is because i have a wilwood hand brake for the rear brakes and the fronts arent hooked up to a prop valve or anything.. i followed the lines and it seems like each outlet on the master cylinder goes to each front brakes.
this is on a 88 crx hf drag car i bought recently that was already set up like this.
Old Oct 24, 2008 | 08:02 AM
1992Si's Avatar
No, on a drag only car.
Old Oct 24, 2008 | 06:34 PM
rintegration's Avatar
Default Re: (1992Si)
Valve is not needed, all it does is reduce pressure to the rear wheels to prevent wheel lockup.
Old Oct 25, 2008 | 06:20 AM
MrBui's Avatar
Default Re: is the brake prop valve needed? (MrBui)
thanks guys... i just wanted to make sure before i end up in the sand pit at the end of the track....
HKSone
Suspension & Brakes
23
Jun 4, 2015 05:59 PM
HKSone
Oct 5, 2009 10:04 AM
MrBui
Suspension & Brakes
Oct 30, 2008 10:29 AM
civic dx
Jun 25, 2003 12:38 AM
SloCivicHMM
14
Feb 6, 2003 03:10 PM
