Which boost controller for guys running 10's and under?
Old Oct 14, 2006 | 08:22 PM
castrol_civic's Avatar
Default Which boost controller for guys running 10's and under?
Currently I RUN 10'S. Im just got my old innovative turbo boost controller back the multi stage with the Co2 config. Im hoping this will help me get into 9's with my 600whp set up. I would use almost no boosty to launch then progress with a timer system.
What boost controller systems are you guys using especially those with traction problems.
Old Oct 14, 2006 | 08:29 PM
vaporboy12's Avatar
Default Re: Which boost controller for guys running 10's and under? (castrol_civic)
that was my main issue with this season got the nlr couldnt get it to work yes i know im dumb.. i ran 20 out the gate and all the way down the track.. went 10.59 like that with a 1.62 60 foot
Modified by vaporboy12 at 2:57 AM 10/16/2006
Old Oct 15, 2006 | 03:38 AM
DaveF's Avatar
Default Re: Which boost controller for guys running 10's and under? (vaporboy12)
nlr boost controller for us. we run this with c02
seems to be working i guess. haha.
Old Oct 15, 2006 | 08:41 PM
Humble Performance's Avatar
Default Re: Which boost controller for guys running 10's and under? (dturbocivic)
Turbo XS Quad stage boost controller.
Old Oct 15, 2006 | 08:48 PM
turbosnatch's Avatar
ams1000 is the **** but its big money
Old Oct 15, 2006 | 10:01 PM
any links to this "NRL" BC? or what is it short for?
Old Oct 16, 2006 | 02:44 AM
Project-D's Avatar
Turbosmart E.Boost II works great! Has all the toys...
Old Oct 16, 2006 | 03:19 AM
Turbocivic94's Avatar
Default Re: Which boost controller for guys running 10's and under? (8secEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8secEg &raquo;</TD></TR><TR><TD CLASS="quote">Turbo XS Quad stage boost controller. </TD></TR></TABLE>
Old Oct 16, 2006 | 04:54 AM
JDogg's Avatar
Default Re: Which boost controller for guys running 10's and under? (Turbocivic94)
aem boost control w/co2 FTW! 45psi of boost on a 10lb spring
Old Oct 16, 2006 | 05:49 AM
tony1's Avatar
Default Re: Which boost controller for guys running 10's and under? (JDogg)
Or if your turbo setup is good, 45psi on a 10lb spring W/O co2!
Old Oct 16, 2006 | 06:10 AM
g2turbo's Avatar
Default Re: Which boost controller for guys running 10's and under? (tony1)
Id also like to hear what you guys are running. Id like a cheaper alternative to some of the more expensive controllers. I like the Innovative MSBC-1 but its pricey. Are you guys having any success with only two levels of boost? Or are you using something different for every gear?
Old Oct 16, 2006 | 07:07 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Or if your turbo setup is good, 45psi on a 10lb spring W/O co2! </TD></TR></TABLE>
yeah, but most people are retards and dont wana listen when they buy the **** so you have to come up w/other ways to make it hold boost
Old Oct 16, 2006 | 07:16 AM
uglyasscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Or if your turbo setup is good, 45psi on a 10lb spring W/O co2! </TD></TR></TABLE> I have been trying to tell Buck that same thing forever. Think he forgot how to K.I.S.S. lol
Old Oct 16, 2006 | 07:26 AM
Default Re: Which boost controller for guys running 10's and under? (g2turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">Id also like to hear what you guys are running. Id like a cheaper alternative to some of the more expensive controllers. I like the Innovative MSBC-1 but its pricey. Are you guys having any success with only two levels of boost? Or are you using something different for every gear?
</TD></TR></TABLE> A $25 Solenoid with AEM, S300 or motec ems's and a properly designed manifold/turbo combination with a low psi spring is the way to go. Spend the money you were going to pay for the Innovative and put it towards the turbo and ems system. I like the turboxs quad stage with a timer for 1st gear but it sucks to wire and get dialed it compared to just setting boost vs duty in the ems.
Old Oct 16, 2006 | 07:29 AM
boostedh22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, but most people are retards and dont wana listen when they buy the **** so you have to come up w/other ways to make it hold boost </TD></TR></TABLE>
Is mainly due to improper turbo sizing creating alot of backpressure??? The reason I ask is I am having issues making more than 30psi of boost. Setup is a 2.3l Subaru, No Co2, GM boost solenoid, Innovative Progate, Innovative Street Heat 61, MoTec M400, etc...
I have messed with spring pressures but have still not been able to make much more than about 334kpa??
So is the bandaid using CO2 into the GM solenoid??
Old Oct 16, 2006 | 07:32 AM
Default Re: Which boost controller for guys running 10's and under? (boostedh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">
So is the bandaid using CO2 into the GM solenoid??</TD></TR></TABLE>Is the wastegate opening?
Old Oct 16, 2006 | 07:34 AM
Default Re: Which boost controller for guys running 10's and under? (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic &raquo;</TD></TR><TR><TD CLASS="quote">Is the wastegate opening?</TD></TR></TABLE>
yes
Old Oct 16, 2006 | 07:40 AM
tony1's Avatar
What's the duty cycle of the boost sol?
A 61mm turbo on a 2.3L motor, i could definitely see it not being able to make over 334kpa with the gate shut.
Old Oct 16, 2006 | 07:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">What's the duty cycle of the boost sol?
A 61mm turbo on a 2.3L motor, i could definitely see it not being able to make over 334kpa with the gate shut.</TD></TR></TABLE>
80% d.c.
Yeah, thats what we were thinking. The exhaust is only a .63 a/r also. Time to upgrade to a bigger turbo over the off season I guess. Just up in the air on which turbo to go with. 40r, 42r???
Old Oct 16, 2006 | 07:56 AM
tony1's Avatar
Well, if you see duty cycle go up on the boost sol. and the boost doesn't go up, then the gate is closing more and the compressor can't make anymore boost, so you're adding more backpressure by closing the gate. Find the least amount of duty cycle that will obtain max. boost and you'll be as good as you can get with that setup.
Old Oct 16, 2006 | 08:14 AM
JDogg's Avatar
dont use the gm soleniod for co2, it cant handle much pressure and you dont get AN fittings on it.
Old Oct 16, 2006 | 08:47 AM
tony1's Avatar
And it doesn't seal all the way, you'll have to turn the co2 on right before you run. lol Been there done that! haha
Old Oct 16, 2006 | 11:22 AM
ssc_thomas's Avatar
so, any recommendations on getting more boost?? bigger turbo? different boost control??
Old Oct 16, 2006 | 12:50 PM
tony1's Avatar
Default Re: (ssc_thomas)
On which setup?
Old Oct 16, 2006 | 01:16 PM
miller's Avatar
Default Re: (tony1)
motec
