Billet Mount Inserts for G-Force shifter
Old Jul 28, 2006 | 01:21 PM
Dragline's Avatar
Default Billet Mount Inserts for G-Force shifter
Just like the title say's
Pics are clickable
Modified by Dragline at 5:33 PM 7/28/2006
Old Jul 28, 2006 | 01:34 PM
SpeedDreamz.com's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (Dragline)
nice
Old Jul 28, 2006 | 01:51 PM
DaveF's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">nice</TD></TR></TABLE>
thats what im thinkin. thats a great idea, are you going to run a bolt through both halfs or is it one solid insert?
also are you running the 2 lower "torque mounts" ??
Old Jul 28, 2006 | 01:58 PM
dome's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (dturbocivic)
[QUOTE=dturbocivic]
there were 6 billet inserts made. still using hasport center shaft. we are going to run a bolt through. cost 150.00 buck. every insert was a different size.
Old Jul 28, 2006 | 02:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Billet Mount Inserts for G-Force shifter (dome)
great idea! Are they Hasport with AL inserts? How much??
art
Old Jul 28, 2006 | 02:15 PM
Johnny O A20 KIller's Avatar
Are the inserts for the motor mounts or the actual tranny mounts?
Old Jul 28, 2006 | 04:34 PM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
also are you running the 2 lower "torque mounts" ??</TD></TR></TABLE>
Ya, the bolt goes through both halfs and the aluminum inserts are pressed in. The 2 torque mounts on the car are being used and are already solid to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">great idea! Are they Hasport with AL inserts? How much??
art</TD></TR></TABLE> Yup, Hasports and I would guess about 80 or maybe alittle more A set depending how many people want them.
Old Jul 28, 2006 | 05:06 PM
msmotorsports's Avatar
How deeply into the mount do these press?
Old Jul 28, 2006 | 08:10 PM
bigTom's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (msmotorsports)
looks good... how do they fit?
Old Jul 28, 2006 | 09:45 PM
locash's Avatar
Every insert did not have to be a different size, they should have been all the same, unless you wanted the inserts to touch each other in the center.. ?
Old Jul 29, 2006 | 03:56 AM
dome's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Every insert did not have to be a different size, they should have been all the same, unless you wanted the inserts to touch each other in the center.. ?</TD></TR></TABLE>
everyone was a different size because not one of the monuts were round. each one had to be sized then made. even the center shaft was not round. the billet inserts are the same size as the bushing. there is a little space between the two in the center. they are all pressed fitted.
Modified by dome at 11:22 AM 7/29/2006
Old Jul 29, 2006 | 05:21 AM
Dragline's Avatar
They are different because the first guy we took them to didn't want to mess with it because he would of had to machine each one different to keep the same tolerances for all of them for the pressed fit.
Old Jul 29, 2006 | 06:16 AM
tony1's Avatar
Hey Joe, what's the possibility of Hasport offering a solid mount? The mounts now start solid before they're machined, right? Should be easy to offer?
Old Jul 31, 2006 | 04:24 AM
Dragline's Avatar
Default Re: Billet Mount Inserts for G-Force shifter (tony1)
That would be nice
Old Jul 31, 2006 | 04:38 AM
ALL IMPORT's Avatar
i would definatly buy a solid mount expecially for the rear mount
Old Jul 31, 2006 | 12:45 PM
locash's Avatar
Unfortunately, they don't all start from a solid block, which explains this problem that some have had with making solid inserts, as the holes can be slightly different when used with urethane.. The other problem is that they would have to be made for a steel pin to pressed into them, as a steel bolt would probably beat the hell out of the aluminum.. I'll look into this in more detail, but I assume only the guys with G-Force shifters would want them, as the rest could probably get away with using a REALLY hard urethane insert, correct?
Old Jul 31, 2006 | 01:40 PM
tony1's Avatar
Primarily the guys with the gforce shifters, and some others that think they need them. lol I know the G Force shifter sales will go up with mounts commercially available because that's the reason alot of them don't end up getting installed. Hell, make the solid mount kit and a "shifter mount kit" and you'll be good to go.
Old Jul 31, 2006 | 03:33 PM
dome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Primarily the guys with the gforce shifters, and some others that think they need them. lol I know the G Force shifter sales will go up with mounts commercially available because that's the reason alot of them don't end up getting installed. Hell, make the solid mount kit and a "shifter mount kit" and you'll be good to go. </TD></TR></TABLE>
sales would go up for sure. make a shifter mount kit so i can buy one .
Old Jul 31, 2006 | 06:52 PM
matt k's Avatar
you can do the same thing with the stock mounts and save some money
Old Jul 31, 2006 | 07:23 PM
Juan Q...'s Avatar
Default Re: Billet Mount Inserts for G-Force shifter (bob menuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob menuts &raquo;</TD></TR><TR><TD CLASS="quote">you can do the same thing with the stock mounts and save some money </TD></TR></TABLE>
true.
For the G-force Inserts. Good Idea!
Old Aug 7, 2006 | 05:52 PM
Hasport are selling these intserts
Old Aug 8, 2006 | 02:42 PM
dome's Avatar
Default Re: (Johnny O A20 KIller)
thought he was telling me. we had the inserts made at a machine shop.
Modified by dome at 8:59 PM 8/8/2006
Old Aug 8, 2006 | 06:13 PM
Dragline's Avatar
Default Re: (dome)
He forgot the ? mark, num nuts
dome
Sep 3, 2007 06:17 AM
stwano
Dec 23, 2006 07:51 PM
boosted_integ
Welding / Fabrication
Jan 22, 2006 04:45 PM
mrbsponge
21
May 27, 2005 06:14 PM
hondapwred95
May 2, 2005 05:29 PM
